Problem with Notifications.
NOTE - The email address is changed you must change this!!!!!!!!!
-- phpMyAdmin SQL Dump
-- version 2.8.2.4
-- http://www.phpmyadmin.net
-- Host: localhost:3306
-- Generation Time: Dec 13, 2008 at 09:48 AM
-- Server version: 5.0.67
-- PHP Version: 5.2.6
-- Database: `psa`
-- Table structure for table `Notifications`
CREATE TABLE `Notifications` (
`id` int(10) unsigned NOT NULL auto_increment,
`status` varchar(1) character set ascii collate ascii_bin NOT NULL,
`send2admin` varchar(1) character set ascii collate ascii_bin NOT NULL,
`send2client` varchar(1) character set ascii collate ascii_bin NOT NULL,
`send2dlu` varchar(1) character set ascii collate ascii_bin NOT NULL,
`send2email` varchar(1) character set ascii collate ascii_bin NOT NULL,
`email` varchar(255) character set utf8 NOT NULL,
`subj` varchar(255) character set utf8 NOT NULL,
`note_id` int(10) unsigned default NULL,
`send2reseller` varchar(1) character set ascii collate ascii_bin NOT NULL,
PRIMARY KEY (`id`),
KEY `note_id` (`note_id`)
) ENGINE=InnoDB AUTO_INCREMENT=23 DEFAULT CHARSET=latin1 AUTO_INCREMENT=23 ;
-- Dumping data for table `Notifications`
INSERT INTO `Notifications` (`id`, `status`, `send2admin`, `send2client`, `send2dlu`, `send2email`, `email`, `subj`, `note_id`, `send2reseller`) VALUES (1, '', 0x31, 0x31, '', 0x31, 'email@domain', '', 1, 0x30),
(2, '', 0x31, 0x31, '', 0x31, 'email@domain', '', 2, 0x30),
(3, '', 0x31, 0x31, 0x31, 0x31, 'email@domain', '', 3, 0x30),
(4, '', 0x31, 0x31, '', 0x31, 'email@domain', '', 4, 0x30),
(5, '', 0x31, 0x31, '', 0x31, 'email@domain', '', 5, 0x30),
(6, '', 0x31, 0x31, 0x31, 0x31, 'email@domain', '', 6, 0x30),
(7, '', 0x31, 0x31, 0x31, 0x31, 'email@domain', '', 7, 0x30),
(8, '', 0x31, 0x31, 0x31, 0x31, 'email@domain', '', 8, 0x30),
(9, '', 0x31, 0x31, 0x31, 0x31, 'email@domain', '', 9, 0x30),
(10, '', 0x31, 0x31, 0x31, 0x31, 'email@domain', '', 10, 0x30),
(11, '', 0x31, 0x31, 0x31, 0x31, 'email@domain', '', 11, 0x30),
(12, '', 0x31, 0x30, '', '', '', '', 12, ''),
(13, '', 0x31, '', '', 0x31, 'email@domain', '', 13, 0x31),
(14, '', 0x31, '', '', 0x31, 'email@domain', '', 14, 0x31),
(15, '', 0x31, '', '', 0x31, 'email@domain', '', 15, 0x31),
(16, '', 0x31, '', '', 0x31, 'email@domain', '', 16, 0x31),
(17, '', 0x31, 0x31, 0x30, 0x31, 'email@domain', '', 17, 0x30),
(18, '', 0x31, 0x31, 0x31, 0x31, 'email@domain', '', 19, 0x30),
(19, '', 0x31, 0x31, 0x30, 0x31, 'email@domain', '', 18, 0x30),
(20, '', 0x31, 0x30, 0x30, 0x31, 'email@domain', '', 20, 0x31),
(21, '', 0x31, 0x31, 0x30, 0x31, 'email@domain', '', 21, 0x30),
(22, '', 0x31, 0x30, 0x30, 0x31, 'email@domain', '', 22, 0x31);
Hi
All working now ;) in the Notifications. Thanks for your patience it was much appreciated. With regards to other bugs, lets hope they fix them soon and strange how my Notes only had 15 entries :(
Thanks
Terry
I am glad! I started the list up here:
http://forum.swsoft.com/showthread.php?goto=newpost&t=56922
Its helpful and I put in short fixes...
I think there are tons of database missing stuff issues. Like the saving info and these bugs all are the same.
Wonder why they bothered with the beta? Thrown plesk 9 out back then and we could have been stable by now.
Good idea, I have just posted another bug I have found.
I have downloaded the installer and got to a page that says the following products versions are available:
1. Plesk Control Panel
2. Parallels Plesk Panel 9.0.0 (currently installed)
3. Sitebuilder
Do I untick ALL or just leave both 1 and 2 ticked???
Thanks
