Resolved Problem with php-fpm
Allan
Hello,
I'm having trouble with php-fpm when I finish installing everything so it's not starting php-fpm and so I can not open the panel to complete the installation.
To install I used the 1-click installation with the command:
sh <(curl https://installer.plesk.com/one-click-installer || wget -O - https://installer.plesk.com/one-click-installer)
I am using CentOS 7 server from Vultr company (https: vultr.com).
see php logs after installation:
[root@servidor log]# cat php-fpm/error.log
[28-Jul-2017 22:21:18] ERROR: No pool defined. at least one pool section must be specified in config file
[28-Jul-2017 22:21:18] ERROR: failed to post process the configuration
[28-Jul-2017 22:21:18] ERROR: FPM initialization failed
Has anyone had this and knows how to solve it?
Regards,
Allan Almeida
Verify: 61/67: psa-libxml-proxy.x86_64 0:2.7.8.1-centos7.17031417 - e
Verify: 62/67: git.x86_64 0:1.8.3.1-6.el7_2.1 - e
Verify: 63/67: plesk-rdbmspp.x86_64 0:2.0.1-centos7.735641.16021112 - e
Verify: 64/67: psa-libpam-plesk.x86_64 0:17.5.3-cos7.build1705170317.16 - e
Verify: 65/67: sw-librrd.x86_64 0:1.6.0.1-centos7.17031414 - e
Verify: 66/67: plesk-engine.x86_64 0:17.5.3-cos7.build1705170622.17 - e
Verify: 67/67: sw-collectd.x86_64 0:5.5.0.1-centos7.17031414 - e
/usr/local/psa/bootstrapper/pp17.5.3-bootstrapper/bootstrapper.sh: line 13079: /usr/local/psa/admin/sbin/f2bmng: No such file or directory
Installing patches...
All files were downloaded. All patches were applied. sh: /usr/local/psa/admin/sbin/update_history: No such file or directory
Patches were installed successfully.
The changes were applied successfully.
There are some errors in this update.
I just installed the server and can not log in, I try to update using the link that sent me but it does not work.
Allan
Please try to repair your installation with these two commands:
# plesk installer --select-release-current --reinstall-patch --upgrade-installed-components
# plesk repair installation
