• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • Support for BIND DNS has been removed from Plesk for Windows due to security and maintenance risks.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS.
Problem with thunderbird
Ahmed.Shabrawy
Hello every one
I have a problem while i'm trying to add a mail account to Thunderbird
I see the problem that Mail server doesn't use encryption !!!
any ideas to solve this problem
In order for you to use encryption, you will need to buy an SSL cert for the domain you want to use. If you don't want to buy a SSL cert, just accept the fact that you're using a self signed cert (which will cause that warning) and put a check mark in the check box for "I understand the risks" and continue on.
