Problem
Eduard
I got the following message
Template processing failed: file = /usr/local/psa/admin/conf/templates/default/domainVhost.php, error = Template_Exception: No data. file: /usr/local/psa/admin/plib/Template/Processor.php line: 28 code: 0 Previous error: Template_Variable_Exception: No data. file: /usr/local/psa/admin/plib/Template/Variable/AbstractCachedData.php line: 67 code: 0.
How can i correct this?
Hello Eduard,
Please, always specify the version of Plesk with microupdate number.
Show the list of files: find /usr/local/psa/admin/conf/templates/ -type f
Add "[log] priority=7" in /usr/local/psa/admin/conf/panel.ini and run "plesk sbin httpdmng --reconfigure-all"
If the problem has been reproduced, show the output from this utility. I need lines starting with "Class: ..." and "Metainfo: ...".
