Problems after upgrade to 10.0.0.
M
MilosS
Since I upgraded to Plesk 10.0.0, updates are not working anymore. In example, I can't update to 10.1. After click on Update, it waits for some time and show no updates or show blank page.
Also, since then, number of databases is not counted properly. In phpMyAdmin, I am getting this warning message: "Your PHP MySQL library version 5.0.90 differs from your MySQL server version 5.1.50. This may cause unpredictable behavior."
Finally, disk usage is not correct. It shows that I am using 114GB (!), but I know that I am using no more than 10GBs.
Thanks
This is the list of the installed components:
awstats 6.95-10080312.swsoft
bind 9.3.6-4.P1.el5_4.2
coldfusion The component was not installed
coldfusion-support The component was not installed
courier-imap 3.0.8-cos5.build108100921.15
drweb The component was not installed
frontpage The component was not installed
health-monitor The component was not installed
httpd 2.2.3-43.el5.centos.3
mailman 2.1.9-4.el5
mod_bw 0.8-10081215
mod_perl 2.0.4-6.el5
mod_python 3.2.8-3.1
mysql 5.1.50-1.el5.art
perl-Apache-ASP The component was not installed
php 5.2.14-2.el5.art
plesk-billing The component was not installed
postfix The component was not installed
postgresql-server The component was not installed
PPSitebuilder 5.0.0-33387.10092415
ppsmbe The component was not installed
ppsmbe-filesharing The component was not installed
psa 10.0.0-cos5.build108101004.13
psa-api-rpc 10.8.0-cos5.build108101004.13
psa-atmail The component was not installed
psa-autoinstaller 3.7.0-100821.20
psa-backup-manager 10.8.0-cos5.build108101004.13
psa-drweb-configurator The component was not installed
psa-horde 3.3.8-cos5.build108100921.15
psa-imp 4.3.7-cos5.build108100921.15
psa-logrotate 3.7-cos5.build108100921.15
psa-migration-manager 10.8.0-cos5.build108101004.13
psa-miva The component was not installed
psa-mod-fcgid-configurator 2.0.0-cos5.build108100921.15
psa-proftpd 1.3.3-cos5.build108100921.15
psa-qmail 1.03-cos5.build108100921.15
psa-qmail-rblsmtpd 0.70-cos5.build108101004.13
psa-rubyrails-configurator 1.1.6-cos5.build108100921.15
psa-spamassassin 10.8.0-cos5.build108101004.13
psa-tomcat-configurator The component was not installed
psa-turba 2.3.4-cos5.build108100921.15
ruby 1.8.5-5.el5_4.8
samba The component was not installed
sitebuilder The component was not installed
spamassassin 3.2.5-1.el5.art
SSHTerm The component was not installed
tomcat The component was not installed
webalizer 2.01_10-30.1
Can somebody help me please? My updates still won't run. I checked ports with command netstat -an | grep LISTEN and I can see that 8447 was open:
tcp 0 0 0.0.0.0:8447 0.0.0.0:* LISTEN
Any thoughts?
