K
kcjames
I have installed Plesk 9.0.1 (full install) on a clean install of fc8 (web server).
Didn't see any issues during install. I just have the temp license installed for testing.
Nothing in the logs is indicating where the problem may be. httpd is running, psa is running, yet I can not browse to the IP or hostname and I can not browse to the admin interface.
The only weird issues are in the /var/log/httpd/error_log. They are as follows:
[Wed Mar 11 09:53:35 2009] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Wed Mar 11 09:53:35 2009] [warn] Init: SSL server IP/port conflict: atmail.webmail:443 (/etc/httpd/conf.d/zzz_atmail_vhost.conf:48) vs. horde.webmail:443 (/etc/httpd/conf.d/zzz_horde_vhost.conf:41)
[Wed Mar 11 09:53:35 2009] [warn] Init: SSL server IP/port conflict: default-192-168-1-2:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:78) vs. horde.webmail:443 (/etc/httpd/conf.d/zzz_horde_vhost.conf:41)
[Wed Mar 11 09:53:35 2009] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Mar 11 09:53:35 2009] [notice] Apache/2.2.6 (Unix) DAV/2 mod_jk/1.2.15 PHP/5.2.6 mod_python/3.3.1 Python/2.5.1 mod_ssl/2.2.6 OpenSSL/0.9.8b mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations
[Wed Mar 11 10:14:07 2009] [notice] caught SIGTERM, shutting down
[Wed Mar 11 10:14:08 2009] [notice] SELinux policy enabled; httpd running as context system_u:system_r:httpd_t:s0
[Wed Mar 11 10:14:08 2009] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Mar 11 10:14:08 2009] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Wed Mar 11 10:14:08 2009] [warn] Init: SSL server IP/port conflict: atmail.webmail:443 (/etc/httpd/conf.d/zzz_atmail_vhost.conf:48) vs. horde.webmail:443 (/etc/httpd/conf.d/zzz_horde_vhost.conf:41)
[Wed Mar 11 10:14:08 2009] [warn] Init: SSL server IP/port conflict: default-192-168-1-2:443 (/etc/httpd/conf.d/zz010_psa_httpd.conf:78) vs. horde.webmail:443 (/etc/httpd/conf.d/zzz_horde_vhost.conf:41)
[Wed Mar 11 10:14:08 2009] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Mar 11 10:14:08 2009] [notice] Digest: generating secret for digest authentication ...
[Wed Mar 11 10:14:08 2009] [notice] Digest: done
[Wed Mar 11 10:14:08 2009] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 28 bytes)
[Wed Mar 11 10:14:08 2009] [notice] mod_bw : Version 0.8 - Initialized [0 Confs]
[Wed Mar 11 10:14:08 2009] [notice] mod_python: Creating 4 session mutexes based on 256 max processes and 0 max threads.
[Wed Mar 11 10:14:08 2009] [notice] mod_python: using mutex_directory /tmp
[Wed Mar 11 10:14:08 2009] [notice] Apache/2.2.6 (Unix) DAV/2 mod_jk/1.2.15 PHP/5.2.6 mod_python/3.3.1 Python/2.5.1 mod_ssl/2.2.6 OpenSSL/0.9.8b mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations
I'm lost. I have tried everything I can think of and the few search results I have been able to locate have been of no help.
Please help!
Please help!
