Resolved Problems of config of Varnish using Docker
greg2017
Hi everybody
I am running this domain [redacted] using Varnish under Docker and it is running perfect
Docker / Varnish
Details
Settings
For a Magento Update I transfered a copy of the shop to a dev server and changed the domain to dachbox2.ch
And set up Docker
Varnish Details
Varnish Settings:
We always got some 503 errors but after changing PHP to FMP by Apache once the error message went away and I only get the Plesk Defaut page:
But his page is not in den FTP directory.
So we think that somehow the settings are wrong or cached.
FYI: I am not a developer but I communicate with a external Linux Expert that does not know Plesk/Docker/Varnish very wel
Thanks a lot for any hints!
Gregor
my developer writs me:
To define that you need to go and update the file /etc/varnish/default.vcland find the following section, that will be configured for our example purpose like this: backend default { .host = "192.168.1.2"; .port = "8080"; .first_byte_timeout = 60s; .connect_timeout = 300s;} It will instruct Varnish to listen the application running at IP 192.168.1.2 and port 8080.
where can we find this file
Thanks!
We did this
in /root we found a default.vcl
this was a kind of active one, but you need to put it inside of container first
commands are:
docker cp default.vcl varnish:/etc/varnish
docker restart varnish
