Problems to Connect Plesk from Outside...
G
Gianni@
Hi
Today i have installed a new Windows 2003 Server. The Installation of Plesk was going without problems...
On the Winodws 2003 Server i can connect ot the Plesk Panel without any Problems! I can configure the Server etc.
But if i use to connect to Plesk from another PC in the Network (or via Internet) i can't!
In the Webbrowser i give in the Adresse: https://<IPADRESS> or <DNS Name>:8443/
But Plesk gives return: https://<IPADRESS>:8443/deleted
So will try to connect via https://<IPADRESS>:8443/login.php3. I see the Login Page and can write in Username and Passwort. But the next side will be searched at https://<IPADRESS>:8443/deleted...
Have anyone the same Problem? Or mutch better... have anyone a solution for this Problem?
Thanks
I've never heard about such problems before...
Probably some firewall or av rejects browser requests....
Have you checked access directly from the server?
