Problems with HTTPS
N
NoWorldOrder
Hello,
I have a problem with access to the https map.
All websites are showing the same page. I searched on the web, and I found a document in the SW Soft website:
http://kb.swsoft.com/en/2166
We did this but still no result.
After that we found something that all websites have one HTTPS unless you use different maps.
Well no problem at all. But how do I first fix the above.
What we want:
1. HTTPS with a blanco page. So customers won’t see the https website from somebody else
2. After that we will setup the special folders in Plesk for https
So: does somebody know how I change the current default page in https?
Because all are forwarded to one single domain now. I would be glad if you can give me some information.
Are you using SSL Support on a shared ip?
In Windows if one domain (example abc.com) has SSL support on a shared ip, will domains in that shared ip will show abc.com's page on https
Remove SSL Support from abc.com or put abc.com in a dedicated (exclusive) ip.
