Issue Problems with installing memcached for PHP 8.2
Martin73
Basic Pleskian
Ubuntu 20.04.5
Obsidian 18.0.49
I was able to install memcached with this work around. This was possible for PHP 8.0 and also for version 8.1. PHP 8.2 however makes problems.
After “service plesk-php82-fpm restart” comes the following message:
Code:
Job for plesk-php82-fpm.service failed because the control process exited with error code.
See "systemctl status plesk-php82-fpm.service" and "journalctl -xe" for details.
After “/opt/plesk/php/8.2/bin/php -m | grep memcached” comes the following message:
Code:
PHP Warning:  PHP Startup: Unable to load dynamic library 'memcached.so' (tried: /opt/plesk/php/8.2/lib/php/modules/memcached.so (/opt/plesk/php/8.2/lib/php/modules/memcached.so: cannot open shared object file: No such file or directory), /opt/plesk/php/8.2/lib/php/modules/memcached.so.so (/opt/plesk/php/8.2/lib/php/modules/memcached.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Why is the file memcached.so not to be found under this path “/opt/plesk/php/8.2/lib/php/modules”? What can I do?
In your message: "/opt/plesk/php/8.2/lib/php/modules/memcached.so.so"
... so.so ? <- may be this might be the problem?!
It's embarrassing. I made the same mistake I did with PHP 8.0. :rolleyes:
The php.ini was the cause. Here are the steps for the installation:
Code:
apt install memcached autoconf automake gcc libmemcached-dev libhashkit-dev pkg-config plesk-php*-dev zlib1g-dev
/opt/plesk/php/8.2/bin/pecl install memcached
add "extension=memcached.so" to php.ini
Following:
Code:
echo "extension=memcached.so" > /opt/plesk/php/8.2/etc/php.d/memcached.ini
plesk bin php_handler --reread
service apache2 restart
