• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Proftpd problem
J
Jean-PhilippeT
I'm on version 9.5.2 on centos.
We did an update via yum and after a week the ftp service stopped working, any connections get 530 login incorrect.
I'm quite new to plesk and I wonder if I will get into troubles if I use the plesk update manager after I did a yum updates.
I also wonder if this will fix my problem or if I should look elsewhere.
thx everyone.
thx for the fast reply but I already tried this and it does not seem to be the problem. It affects all users/all domains on the box, not just one user.
any other cue ?
Tried too, problem still.
according to every post I've read everything should be working now.
I probably missed one little thing somewhere.
1. make sures that /etc/proftpd.conf contains directivies
AuthPAM on
AuthPAMConfig proftpd
2.check /etc/pam.d/proftpd, it should be equal with:
cat /etc/pam.d/proftpd
#%PAM-1.0
auth required pam_listfile.so item=user sense=deny file=/etc/ftpusers onerr=succeed
auth required pam_stack.so service=system-auth
auth required pam_shells.so
account required pam_stack.so service=system-auth
session required pam_stack.so service=system-auth
[root@a10-52-35-213 ~]#
Everything seems fine, maybe it's cause I'm on plesk 9.5.2.
here's my proftpd.conf file, afaik everyhting is fine
# To have more informations about Proftpd configuration
# look at : http://www.proftpd.org/
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "ProFTPD"
#ServerType standalone
ServerType inetd
DefaultServer on
<Global>
DefaultRoot ~ psacln
AllowOverwrite on
</Global>
DefaultTransferMode binary
UseFtpUsers on
TimesGMT off
SetEnv TZ :/etc/localtime
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
#Following part of this config file were generate by PSA automatically
#Any changes in this part will be overwritten by next manipulation
#with Anonymous FTP feature in PSA control panel.
#Include directive should point to place where FTP Virtual Hosts configurations
#preserved
ScoreboardFile /var/run/proftpd/scoreboard
# Primary log file mest be outside of system logrotate province
TransferLog /usr/local/psa/var/log/xferlog
#Change default group for new files and directories in vhosts dir to psacln
<Directory /var/www/vhosts>
GroupOwner psacln
</Directory>
#Enable PAM authentication
AuthPAM on
IdentLookups off
UseReverseDNS off
AuthGroupFile /etc/group
Include /etc/proftpd.include
# <IfModule mod_tls.c>
# TLSEngine on
# TLSLog /var/log/tls.log
# TLSProtocol SSLv23
# Are clients required to use FTP over TLS?
# TLSRequired off
# Server's certificate
# TLSRSACertificateFile /usr/local/psa/admin/conf/httpsd.pem
# TLSRSACertificateKeyFile /usr/local/psa/admin/conf/httpsd.pem
# Authenticate clients that want to use FTP over TLS?
# TLSVerifyClient off
# Allow SSL/TLS renegotiations when the client requests them, but
# do not force the renegotations. Some clients do not support
# SSL/TLS renegotiations; when mod_tls forces a renegotiation, these
# clients will close the data connection, or there will be a timeout
# on an idle data connection.
# TLSRenegotiate required off
# </IfModule>
thx
Porovide more information, show output of commands:
1. ls -al /etc/xinetd.d/ | grep ftp
2. cat /etc/xinetd.d/ftp_psa
-rw-r----- 1 root root 287 Nov 9 12:23 ftp_psa
-rw-r--r-- 1 root root 326 Oct 5 07:46 gssftp
service ftp
disable = no
socket_type = stream
protocol = tcp
wait = no
user = root
instances = UNLIMITED
server = /usr/sbin/in.proftpd
server_args = -c /etc/proftpd.conf
doesn't fix it.
same error
any other cue ?
thx for the help btw, this is greatly appreciated.
by the way, backup /etc/pam directory and call /usr/local/psa/pam_plesk_config/pam_plesk_install -qq
/etc/pam.d/proftpd
#%PAM-1.0
#auth required pam_unix.so nullok
#account required pam_unix.so
#session required pam_unix.so
doez pam_plesk_install helps?
If not, need to do additional steps:
doez FTP user under U try to login exist in /etc/ftpusers?
provide /etc/ftpchroot
1. tail -f /var/log/messages |& tee /tmp/MESS
2. try to login under domain FTP user
3. provide /tmp/MESS
No doez pam_plesk_install did nothing useful.
When I create a new user with ftp access it does not appear in /etc/ftpusers, that smells problematic.
U do not provide info only partly, so its not enought. Sytem log are need (look my prev. post)
not, that well
cat /etc/ftpchroot
@psacln
cat /tmp/MESS
Jan 20 09:53:14 cl-t205-534cl xinetd[9050]: START: smtp pid=32135 from=85.198.158.199
Jan 20 09:53:32 cl-t205-534cl xinetd[9050]: EXIT: smtp status=1 pid=32125 duration=55(sec)
Jan 20 09:53:52 cl-t205-534cl xinetd[9050]: EXIT: smtp status=1 pid=32135 duration=38(sec)
Jan 20 09:53:53 cl-t205-534cl xinetd[9050]: START: smtp pid=32142 from=85.198.158.199
Jan 20 09:53:57 cl-t205-534cl sshd[32143]: rexec line 87: Unsupported option UsePAM
Jan 20 09:54:14 cl-t205-534cl xinetd[9050]: EXIT: smtp status=1 pid=32142 duration=21(sec)
Jan 20 09:54:55 cl-t205-534cl xinetd[9050]: START: smtp pid=32181 from=206.162.158.162
Jan 20 09:54:56 cl-t205-534cl xinetd[9050]: EXIT: smtp status=0 pid=32181 duration=1(sec)
Jan 20 09:55:32 cl-t205-534cl xinetd[9050]: START: smtp pid=32195 from=66.36.150.85
Jan 20 09:56:32 cl-t205-534cl xinetd[9050]: EXIT: smtp status=0 pid=32195 duration=60(sec)
Jan 20 09:57:39 cl-t205-534cl proftpd[32262]: 174.142.68.104 :):ffff:66.46.166.146[::ffff:66.46.166.146]) - FTP session opened.
