Proftpd problem
It seems that I cannot post chkconfig --list on the board so it's in an attached text file
  • chkconfig --list .txt
Attached in text file again
grep ftp /var/log/secure
  • grep ftp varlogsecure.txt
try to change password for user 'noise' temporary
passwd noice <<< type any dummy here, for example 'qweqwe' and try to login again
still not working with that pam.d.
the smtp service has no problem with it.
Output of su -l $FTP_USER -s '/bin/sh' -c 'cat /etc/{passwd,group}' provide actual data?
In additional provide permission for /etc/{passwd,group}, also try to login with selinux turned off.
ls -l /etc/{passwd,group}
-rw-r--r-- 1 root root 1102 Nov 23 12:13 /etc/group
-rw-r--r-- 1 root root 3651 Jan 20 13:51 /etc/passwd
other results are in the attached text file, all my ftp users are there.
  • su -l $FTP_USER -s ':bin:sh' -c 'cat :etc:{passwd,group}'.txt
on server exec strace -f -s 1024 -o /tmp/STRACE /etc/init.d/xinetd restart
try to login under FTP user and attach /tmp/STRACE (do not forget to hide password in STRACE)
This one went wrong
I did the strace, logged with a ftp account used on the box, sended a stop signal(ctrl-c) to strace that the process ignored.
At the meantime smtp auth started to failed.
retsarted xinetd, smtp auth came back ok and strace stopped.
Now in /tmp/STRACE, when I grep for the user name used on the ftp login I have nothing so it's like I never tried login via ftp.
All the rest is tracked down by strace except that ftp login, I see all smtp auth trial failing one after another etc.
tried twice and I always get the same results.
possible need to wait until xinet.d service perform restart
in another console call /etc/init.d/xinetd restart, should be enought
I waited for the message xinet.d stop/start to finish before proceeding.
I will have another look at all this today.
yeah that worked okay, just founded it weird a bit.
Is it normal that using strace on xinet.d prevent my smtp auth to work properly ?
I'm on version 9.5.4 on Fedora 8 and have the same problem after a yum update.
I tried all solutions and problem still (530 Login Incorrect for all users). Any solutions?
still trying to figure why ftp login doesn't show up in xinet.d strace
I solve the problem! I found the solution here http://forum.parallels.com/showthread.php?t=87980.
The yum update change the '/etc/pam.d/proftpd'.
#%PAM-1.0
auth required pam_listfile.so item=user sense=deny file=/etc/ftpusers onerr=succeed
auth required pam_stack.so service=system-auth
auth required pam_shells.so
account required pam_stack.so service=system-auth
session required pam_stack.so service=system-auth
I changed /etc/pam.d/proftpd to match a fedora server without the update ( 1.3.1 )
#%PAM-1.0
auth include system-auth
account include system-auth
session include system-auth
session required pam_loginuid.so
Thank you very much Sito, this fix works fine for me.
#%PAM-1.0
#%PAM-1.0
