SOLVED - Problem Health Monitor Server
Manuel_Caramia
Regular Pleskian
Hi, I want to know if there is a guide to check and stop programs that are using to many ram. It is over 65% and this is not very normal. Thanks.
hi @abdi and thanks for you answere.
I wanted to check what domain consumed more ram but I noticed that the services of server status are at 0. In fact, if I open and I click on Server Status: scan for hardware changes, I get this error:
Error: Execution failed. Command: /bin/df Arguments: Array ( [0] => -Pl ) Details: /bin/df: ` (deleted)/var/named/chroot/etc/named.rfc1912.zones': No such file or directory /bin/df: ` (deleted)/var/named/chroot/etc/named.iscdlv.key': No such file or directory /bin/df: ` (deleted)/var/named/chroot/etc/named.root.key': No such file or directory
(ALSO UNDER THIS COMMAND: /usr/local/psa/bin/sw-engine-pleskrun /usr/local/psa/admin/plib/scripts/setup-health-monitor.php
I tried to follow some guides and give this command:
/usr/local/psa/bin/repair --update-vhosts-structure
but without success.
How can I reinstall the package?
I read this also: http://kb.odin.com/en/114307
@IgorG after your command and then reinstall from web gui I receive this:
The Yum utility failed to install the required packages.
How can I install from command line?
thank you so much
@IgorG I solved "The Yum utility failed to install the required packages" with this command "yum clean all" and reinstall Helat Monitor Server in web GUI.
I also have launched 'plesk repair dns' but I receive the same error:
What is result of command 'plesk repair dns'? Any errors in output or what?
If I correctly understood you have Plesk installed on Virtuozzo VPS? In this case just unmount these points:
# umount /var/named/chroot/etc/named.rfc1912.zones
# umount /var/named/chroot/etc/named.iscdlv.key
# umount /var/named/chroot/etc/named.root.key
@IgorG with your commands I dont receive more errors but in Health Server Status all statistics are 0% usage and if I click on 'scan for hardware changes' I have no success.
Thank you so much
