SSL Problem
Hi NicolaiVdS,
please be aware, that you have to tell Plesk, which certificate it should use to secure the Plesk Control Panel:
Home > Tools & Settings > SSL Certificates :
Hi NicolaiVdS,
and why don't you add the certificate here as well, so you that you are able to secure the Plesk Control Panel with it as well? You only should use a different name, but this isn't a real problem, don't you think as well?!?
