Statistics problem
A
alexsc
I'm having a problem with the Plesk statistics.
The statistics are being generated as I can see the files in:
eg /var/www/vhosts/domain.tld/statistics/webstat/
The webstat folder has the index.html etc in there.
The problem is that I can't actually access the generated statistics from:
eg http://domain.tld/plesk-stat/webstat/
Does anyone know what the problem is?
Thanks,
Alex
It just comes up with the default MSIE eror: Internet Explorer cannot display the webpage.
I'm not a IE user, but I suppose you just mean a 404 error?
Do you get the same results for every domain, or is it just for this single domain? Has it ever worked before on your server?
Yes sorry a 404 error.
It works on 2 domains that I am aware of from the 30 or so domains I have.
It's not like it stopped working at a certain point as it doesn't work on some domains I added before the domain that has statistics working.
I ahve a cron job that generates the statistics.
And it is generating them because I can see the files in /var/www/vhosts/domain.tld/statistics/webstat/
So it's just a question of how to access these statistics I guess
Originally posted by alexsc
So it's just a question of how to access these statistics I guess [/B]
Well, you should be able to access the statistics via <domain>/webstat or <domain>/plesk-stat/webstat. Of course this only works if you have enable "create web statistics" in the domain's hosting setup in Plesk.
It might be a configuration error, you could run this script to fix your httpd configuration for your domains (I don't know if it'll solve your problem, but it's worth a try):
$ /usr/local/psa/admin/bin/websrvmng -a -v
$ service httpd restart
Create web statistics" in the domain's hosting setup in Plesk is enabled, and its working as the statistics are being generated.
I tried the paths you said I should try but neither of them work for most domains. The <domain>/plesk-stat/webstat path works for only teh 2 domians.
I checked all plesk settings between a domain that has statistics working with a domain where it doesn't work, but the settings related to statistics are the same.
I just ran those 2 commands and then regenerated the statistics using command $ /usr/local/psa/admin/sbin/statistics but this was unsuccessfull.
Do you know what else could fix the problems I am having?
Check the ownership of index.html file in /var/www/vhosts/<yourdomain.tld>/statistics/webstat/ folder. It should be <root><psaserv>, if not then change the ownership. This should solve your problem.
There was a problem with my https service.
Its fixed now and the stats are working again :D
