• Hi, Pleskians! We are running a UX testing of our upcoming product intended for server management and monitoring.
    We would like to invite you to have a call with us and have some fun checking our prototype. The agenda is pretty simple - we bring new design and some scenarios that you need to walk through and succeed. We will be watching and taking insights for further development of the design.
    If you would like to participate, please use this link to book a meeting. We will sent the link to the clickable prototype at the meeting.
  • The ImunifyAV extension is now deprecated and no longer available for installation.
    Existing ImunifyAV installations will continue operating for three months, and after that will automatically be replaced with the new Imunify extension. We recommend that you manually replace any existing ImunifyAV installations with Imunify at your earliest convenience.
Resolved Trying to get NodeJS 8 to work. Need some help.
MrM
I am happy with the Plesk NodeJS extension, which works well on my system. However, the latest version Plesk currently supports is 7.4.0 and the latest NodeJS release at the time of writing is 8.1.3. So I tried to install this latest release (see steps below). But I cannot select the installed version from the NodeJS version selection dropdown. Does anybody know what steps I am missing?
What I did:
Install NodeJS 8.x
Code:
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
sudo apt-get install -y nodejs
Register NodeJS with Plesk
(as found in this thread Question - Possible to install node 4.x)
Code:
plesk sbin nodemng register /usr/bin/node
The output of the registered NodeJS versions:
Code:
root@myserver:~# plesk sbin nodemng versions
v8.1.2 /usr/bin/node
v6.9.1 /opt/plesk/node/6/bin/node
v7.4.0 /opt/plesk/node/7/bin/node
System details:
- Plesk Onyx 17.5.3 Update #11
- Node.js extension 1.3.2-78
- Ubuntu 16.04.2 LTS‬
Go to Extensions (left menu) -> My Extensions -> Node.js -> Go To Extension.
Here will be the list of available Node versions. Click Refresh button and you'll see version 8 available.
  • Like
Reactions: MrM
