Unsatisfied dependencies for sw-engine | Plesk broke, how to repair?
Mao
I'm getting those error below from my Plesk 9.5.4.
Those dependencies were actually installed. Is there a way to fix this without re-installing Plesk? I tried to run autoupdater, I selected a same release (9.5.4), but it didn't help. Thanks.
[root@server ~]# tail -n 15 /var/log/sw-cp-server/error_log
2011-07-08 14:16:25: (mod_fastcgi.c.1000) the fastcgi-backend /usr/bin/sw-engine-cgi -c /usr/local/psa/admin/conf/php.ini -d auto_prepend_file=auth.php3 -u psaadm failed to start:
2011-07-08 14:16:25: (mod_fastcgi.c.1004) child exited with status 127 /usr/bin/sw-engine-cgi -c /usr/local/psa/admin/conf/php.ini -d auto_prepend_file=auth.php3 -u psaadm
2011-07-08 14:16:25: (mod_fastcgi.c.1007) if you try do run PHP as FastCGI backend make sure you use the FastCGI enabled version.
You can find out if it is the right one by executing 'php -v' and it should display '(cgi-fcgi)' in the output, NOT (cgi) NOR (cli)
For more information check http://www.lighttpd.net/documentation/fastcgi.html#preparing-php-as-a-fastcgi-program
2011-07-08 14:16:25: (mod_fastcgi.c.1012) If this is PHP on Gentoo add fastcgi to the USE flags
2011-07-08 14:16:25: (mod_fastcgi.c.1105) [ERROR]: spawning fcgi failed.
/usr/bin/sw-engine-cgi: error while loading shared libraries: libxmlrpc_cpp.so.3: cannot open shared object file: No such file or directory
2011-07-08 22:43:09: (mod_fastcgi.c.1000) the fastcgi-backend /usr/bin/sw-engine-cgi -c /usr/local/psa/admin/conf/php.ini -d auto_prepend_file=auth.php3 -u psaadm failed to start:
2011-07-08 22:43:09: (mod_fastcgi.c.1004) child exited with status 127 /usr/bin/sw-engine-cgi -c /usr/local/psa/admin/conf/php.ini -d auto_prepend_file=auth.php3 -u psaadm
2011-07-08 22:43:09: (mod_fastcgi.c.1007) if you try do run PHP as FastCGI backend make sure you use the FastCGI enabled version.
2011-07-08 22:43:09: (mod_fastcgi.c.1012) If this is PHP on Gentoo add fastcgi to the USE flags
2011-07-08 22:43:09: (mod_fastcgi.c.1105) [ERROR]: spawning fcgi failed.
###################################3
[root@server ~]# rpm -V sw-engine
Unsatisfied dependencies for sw-engine-2.0-5.201006091004.centos5.x86_64: /usr/lib64/sw/libxmlrpc.so.3, /usr/lib64/sw/libxmlrpc_cpp.so.3, /usr/lib64/sw/libxmlrpc_server.so.3, /usr/lib64/sw/libxmlrpc_util.so.3, /usr/lib64/sw/libxmlrpc_xmlparse.so.3, /usr/lib64/sw/libxmlrpc_xmltok.so.3
