Updated Plesk and it crashed. Need help Please!
ShelbyM
I updated Plesk 8.2 to Plesk 9.5.4 and everything crashed. All my websites went down and I couldn't get into Plesk. Godaddy brought my websites back up but I still cannot get into Plesk. Godaddy says they cannot help me get into Plesk that I have to fix that myself. They sent me some instructions on how to repair Plesk but in the instructions it says to use the bootstrapper file. I do not have the bootstrapper file in Plesk 8.2 to repair it with. Below is the message that I get when I go to Plesk:
ERROR: PleskFatalException
Components::componentUpdate() failed: Unable to exec utility packagemng: packagemng: Unable to clean BackendCache in DB: Table 'psa.BackendCache' doesn't exist
Additionally, an exception has occurred while trying to report this error: PleskMainDBException
MySQL query failed: Table 'psa.PersistentCache' doesn't exist
0: auth.php3:491
I am very new at all this so if you could please give me some detailed instructions on how to fix this I would really appreciate it.
Here is part of the email that I received after Plesk crashed. Someone please help me solve this problem.
===> Installing Virtual Hosts Directory
===> Installing Apache Server
Trying to stop service httpd... httpd (pid 26335 26334 26333 22388 19930 19838 17676 16328 18119) is running...
Stopping httpd: /etc/rc.d/init.d/functions: line 156: 28144 Killed usleep 100000
/sbin/service: line 68: 28138 Segmentation fault env -i LANG="$LANG" PATH="$PATH" TERM="$TERM" "${SERVICEDIR}/${SERVICE}" ${OPTIONS}
WARNING!
During the stop found some problems(see log file: /tmp/psa_9.5.4_cos4.build95101209.08_upgrade.120305.18.25.log)
Continue...
Copying apache files... /var/tmp/rpm-tmp.93176: fork: Cannot allocate memory
error: %post(psa-9.5.4-cos4.build95101209.08.i586) scriptlet failed, exit status 128
Trying to start service mysqld... done
Trying to establish test connection... connected
done
Trying to create temporary database storage... done
Trying to upgrade persistent database storage... done
Trying to install PAM module... done
done
ERROR: PleskMainDBException
MySQL query failed: Unknown column 'type' in 'where clause'
0: common_func.php3:206
db_query(string 'SELECT COUNT(*) FROM clients where type <> "admin"')
1: common_func.php3:3569
KeyLimitsChecker::getClientsUsed()
2: common_func.php3:3459
KeyLimitsChecker::checkEasyMisused(boolean false)
3: common_func.php3:3299
KeyLimitsChecker::checkKey(boolean false)
4: common_func.php3:3497
KeyLimitsChecker::resetKeyLocks()
5: cmd_loginup.php:137
createSession(string 'admin', string '*******', boolean true, boolean false, integer '-1')
6: cu.php:619
cu->setSession()
7: cu.php:218
cu->cu()
8: update_notifications.php:83
WARNING!
During the cannot update notifications. Please rerun /usr/local/psa/admin/plib/scripts/update_notifications.php manyally found some problems(see log file: /tmp/psa-api-rpc_9.5.4_cos4.build95110630.11_upgrade.120305.18.25.log)
Continue...
6: cu.php:619
cu->setSession()
7: cu.php:218
cu->cu()
8: create_default_templates.php:354
WARNING!
During the default tempaltes cannot be created found some problems(see log file: /tmp/psa-api-rpc_9.5.4_cos4.build95110630.11_upgrade.120305.18.25.log)
Continue...
The installed Plesk release (82070918.10) does not require this hotfix release (9.5.4).
Thank you for choosing our products!
Stopping Courier-IMAP server:
Stopping imap [ OK ]
Stopping imap-ssl [ OK ]
Stopping pop3 [ OK ]
Stopping pop3-ssl [ OK ]
Starting Courier-IMAP server:
Starting imapd [ OK ]
Starting imap-ssl [ OK ]
Starting pop3 [ OK ]
Starting pop3-ssl [ OK ]
Error: An error occurred during installation of packages.
Attention! Your software might be inoperable.
Please, contact product technical support.
