Upgrade 11.5 to 12 problems
choldim
System is CentOS 6.5
Code:
# ./bootstrapper.sh repair
Started bootstrapper repair procedure. This may take a while.
Certain actions may be skipped if not applicable.
**** Product repair started.
===> Checking for previous installation ... not found.
 Trying to start service mysqld... mysqld (pid  30224) is running...
done
 Trying to establish test connection... connected
done
done
done
 Trying to find psa database... version is 011005030
DATABASE ERROR!!!
Previous product version is , but previous database
version is 011005030. In most of cases it is result of
previous upgrade try failure. Please, restore previous version
from backup, and try again or contact technical support.
ERROR while trying to check database version
Check the error reason(see log file: /var/log/plesk/install/plesk_12.0.18_repair.log), fix and try again
*****  problem report *****
In x.x.x.x::8443
ERROR: Zend_Db_Statement_Exception: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'psa.SessionContexts' doesn't exist (Pdo.php:234)
Control panel and emails down...any ideas? thanks
The content of /etc/my.cnf
lower_case_table_names is not enabled
[mysqld]
# bind-address=127.0.0.1
local-infile=0
datadir=/var/lib/mysql
socket=/var/lib/mysql/mysql.sock
user=mysql
# Disabling symbolic-links is recommended to prevent assorted security risks
symbolic-links=0
[mysqld_safe]
log-error=/var/log/mysqld.log
pid-file=/var/run/mysqld/mysqld.pid
