Upgrade problem
A
Avalanchis
I'm encountering an error during the automatic update process.
It appears to be a permissions problem. What are the correct permissions for this folder?
Here is the last part of the upgrade log:
Patching file C:\Program Files (x86)\Parallels\Plesk\admin\panel\application\resources\languages\zh-CN\controllers\business-model-upgrade\notes.php
Execute C:/ParallelsInstaller/send-error-report.exe install
Error: can't apply patch panel-10.4.4~patch14
Access is denied. (Error code 5) at retrieves attributes for file or directory C:\Program Files (x86)\Parallels\Plesk\admin\panel\application\resources\languages\zh-CN\controllers\business-model-upgrade\.aiupd_4664
Warning! Not all packages were installed.
Please check if your system services are operable.
Please try installing packages again later.
Please resolve this issue and try installing the packages again.
If you cannot resolve the issue on your own, contact product technical support for assistance.
