R
rkelley
I have been trying to upgrade form 7.1.7 to 7.5.4 for about 8 hours now and I desperatly need some help. The install process seems to go fine but after a while it says:
so i open up the log file that it speaks of and see this:
Any body got any ideas?
PHP:
Trying to untar named run-root directory structure... done
Trying to set up default permissions...
ERROR while trying to set up default permissions
Check the error reason(see log file: /tmp/psa_7.5.4_RedHat_el3_build75050824.12_upgrade.log), fix and try again
Aborting...
error: %post(psa-7.5.4-rhel3.build75050824.12) scriptlet failed, exit status 1
PHP:
quotacheck: Checked 26302 directories and 568290 files
Trying to check for quota support... done
===> Installing and configuring Named Server
Trying to untar named run-root directory structure... mknod: `dev/random': File exists
mknod: `dev/urandom': File exists
done
Trying to set up default permissions... /var/named/run-root
/var/named/run-root/etc
/var/named/run-root/etc/rndc.conf.sample
/var/named/run-root/etc/named.conf.default
/var/named/run-root/etc/localtime
/var/named/run-root/etc/named.conf.upgrader_saved
/var/named/run-root/var
/var/named/run-root/var/run
/var/named/run-root/var/run/named
/var/named/run-root/var/PROTO.localhost.rev
/var/named/run-root/var/make-localhost
/var/named/run-root/var/named.root
/var/named/run-root/var/localhost.rev
/var/named/run-root/var/somedomain.com
/var/named/run-root/var/146.98.66.in-addr.arpa
/var/named/run-root/var/somedomain.org
/var/named/run-root/var/stats.somedomain.somedomain.com
/var/named/run-root/var/somedomain.net
/var/named/run-root/var/147.98.66.in-addr.arpa
/var/named/run-root/var/somedomain.us
/var/named/run-root/dev
/var/named/run-root/dev/random
/var/named/run-root/dev/urandom
/var/named/run-root/var/somedomain.com/var/named/run-root/var/somedomain.com
find: /var/named/run-root/proc/7254/fd/4: No such file or directory
Aborting...
