view webstat problem
L
LucaF
hi all
i make a vhost_ssl.conf (in the conf dir of the domain) with this rule
AddType application/x-httpd-php .phtml .pwml .php5 .php4 .php3 .php2 .php .inc .html
and run /usr/local/psa/admin/sbin/httpdmng --reconfigure-domain domain.tld
After this also files .html are processed server side and i can write php script into html files, it work fine.
The problem is that now if i call https://www.domain.tld/webstat i received an error and request to save file ... what is worng? I need to add other rule in vhost_ssl.conf ?
I saw that if i delete the vhost_ssl.conf webstat turn to work correctly....
Second question: after upgarde to Plesk 10.x all domain hosted when i call https://www.domain.tld where automatically redirect in showing httpdocs content, can I disable this redirect and how?
I'm working on
Parallels Plesk Panel v10.0.1_build109101029.19 os_CentOS 4.2
OS Linux 2.6.9-89.33.1.plus.c4smp
Thanks in advanced
Luca
Same webstat problem
I am having the same problem since I upgraded from 9 to 10.
My current version is 10.2.0
Is there anyone can help on this issue?
