    CentOS2Alma discussion
Issue Why My IP addresses Interface having problem in loading
jacksapeow
Hello Everyone.
I'm talking about server 2012 R2. The interface available at Tools & Settings >> IP addresses loads and shows all IP addresses.
Unfortunately, clicking on about half the IP addresses shows a page without some text replacements unassigned and little other data. Here's a copy & paste of some of the content:
Public IP address [_]
You can use a public IP address if your Plesk server is behind NAT
The IP address is distributed as
[_] Shared
[x] Dedicated
SSL/TLS certificate [...]
Default site [...]
[[secureFtpSection]]
[[ftpOverSsl]]
[[ftpOverSslOptionRequired]]
[[ftpOverSslOptionEnabled]]
[[ftpOverSslOptionDisabled]]
[[ftpOverSslCustomDisabledHint]]
hello @jacksapeow ,
there were problems with localization couple versions ago, but in 18.0.35.1 all of them should be fixed.
please be sure that you have the latest Obsidian installed.
you can install all available updates through UI at T&S > Updates or with CLI using command plesk installer update (in case you are already using 18.0.35)
or you can upgrade your current installation with command plesk installer upgrade PANEL_18_0_35_WIN (or through UI)
