Forwarded to devs WordPress Toolkit brakes alle other Sites
B4c4rd1
Regular Pleskian
User name: B4c4rd1
TITLE
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
Version 18.0.27 Update #1
CloudLinux 7.8 (Alexei Leonov)
WordPress Toolkit 4.8.1-3636
PROBLEM DESCRIPTION
If the option: Enable bot protection on a activated WordPress Toolkit Site, this option causes all other sites to stop working.
The WordPress Apache rules are copied to each subscription host file. Is that so correctl? That may only be integrated into httpd.conf and nginx.conf, where WordPress has also been activated or installed.
This rule are copied to all subscription httpd and nginx config and breaks the functionality:
Apache config:
        <IfModule mod_rewrite.c>
            <DirectoryMatch /var/www/vhosts/******/public>
                RewriteEngine on
                RewriteCond %{HTTP_USER_AGENT} "(?:acunetix|BLEXBot|domaincrawler\\.com|LinkpadBot|MJ12bot/v|majestic12\\.co\\.uk|AhrefsBot|TwengaBot|SemrushBot|nikto|winhttp|Xenu\\s+Link\\s+Sleuth|Baiduspider|HTTrack|clshttp|harvest|extract|grab|miner|python-requests)" [NC]
                RewriteRule .* - [F,L]
            </DirectoryMatch>
        </IfModule>
STEPS TO REPRODUCE
- Create a main domain
- Create second domain
- Create a sub domain on main domain
- Create a sub domain on second domain
- Create a wordpress instanz with aps installation on www.maindomain.de/testwp
- Activate ALL security options
- Reload httpd
ACTUAL RESULT
All other host on this subscription are broken. URLs trigger a 404 error. For example: www.seconddomain.de/subdir/ or test.seconddomain.de/subdir/ (Subdirs rewriten by .htaccess)
EXPECTED RESULT
The WordPress configuration may only be added to httpd.conf and nginx.conf, where wordpress is located or installed and not to the other vhost configurations.
ANY ADDITIONAL INFORMATION
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM
Confirm bug
Hi @B4c4rd1,
This issue was fixed in WPT 4.8.2, which was published a couple of minutes ago. Let us know if you continue to experience any related issues.
