Issue 413 Request Entity Too Large after changing client_max_body_size
Anbosuki
Ubuntu 22.04.1 LTS
Plesk Obsidian Version 18.0.44 Update #1
Hello, I am running a docker-compose project with python as codebase on a Ubuntu (22) Plesk (18.0.44) server. Now I have a problem that I cannot upload a file with ~1.1GB of size. I changed the value of `Maximum allowed HTTP request body size` under `Domain > my.domain > Hosting & DNS > Apache & nginx Setting` to `2048M` (which then got converted to 2GB). Which worked fine at first, because without that change I instantly got the response that my request is too large (directly from nginx). But after waiting for the file to upload in the end I got basically the same error like the following:
exceeds max_body of 1073741824
(generated by waitress)
I don't know where that value comes from. When I check the log of my container I just see the following:
[warn] 10#10: *72 a client request body is buffered to a temporary file /var/cache/nginx/client_temp/0000000001, client: *.*.*.*, server: , request: "POST /api/uploads HTTP/1.0", host: "my.domain", referrer: "https://my.domain/upload"
[error] 10#10: *72 readv() failed (104: Connection reset by peer) while reading upstream, client: *.*.*.*, server: , request: "POST /api/uploads HTTP/1.0", upstream: "http://*.*.*.*:6666/uploads", host: "my.domain", referrer: "https://my.domain/upload"
Can anyone help me solve this problem?
Thanks for any help in advance :)
What is listening upstream? You have to configure that too.
If it's PHP, then in the PHP settings.
E.g.:
Hello, thank you for the reply.
Since it's python I actually completely deactivated php for my website. So that's not the problem.
I am not sure, but I think the problem has something to do with my docker nginx config. I now get the error:
