• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
Access to the web interface of mailman problem - using plesk on mediatemple.net
J
jorgitobg
hi,
I can make a lists without problems, but i cant access to the mailman´s web interface... i was searching a bit on google and i found this is usually a DNS misconfiguration problem....
While Plesk must configure all automatically it appears to be some error with dns configuration between plesk on server and mediatemple.net dns... i cant access to the domain lists.amigosdetoledo.org or any other of my domains begining with lists.
Could someone help me with this problem?
How could i check the server configuration for the http is correct?
Regards,
he there, try this:
http://kb.swsoft.com/en/1612
The Mailman web interface is not working. I get "domain cannot be found" DNS error when try to access it.
The domain cannot be resolved. I get "The page cannot be displayed" error when trying to open a domain.
http://kb.swsoft.com/article_20_765_en.html
I found that the "Mailman Settings" icon is greyed out on the Server page in Plesk Control Panel. What does it mean?
http://kb.swsoft.com/en/1638
How do I install Mailman with Plesk? What versions is recommended? Are there any other steps needed to configure Mailman?
http://kb.swsoft.com/en/1637
Info on mailman configuration:
http://www.washington.edu/computing/mailman/faqs/
Mailman troubleshooting, messages are not delivered to the lists' subscribers.
http://kb.swsoft.com/en/1614
hope it helps a bit.
