Another Backup-Problem
CarstemA
Hello I ´ve 11.5.30 Update #3 on CentOS 5.8 (Final),
my Problem ist, that Backup width cron doesn´t work. cli is no Problem (works with ftp)
I think it ist since update on 11.5.30 in July (I don´t know exactly, because I get this server this week)
When I look in /usr/local/psa/PMM/logs/pmmcli_daemon.log I can see:
Code:
[2013-10-29 14:53:47] Action PmmcliLogRotateAction started
[2013-10-29 14:53:47] Action param: file_name:migration.log
[2013-10-29 14:53:47] rename log file to /usr/local/psa/PMM/logs/migration.log.2013-10-29-145347
[2013-10-29 14:53:47] Action param: file_name:migration_handler.log
[2013-10-29 14:53:47] Action DaemonTaskDeleteTempDumpAction started
[2013-10-29 14:53:47] Action param: dump_specification_formatter:
<dump-specification>
    <dumps-storage-credentials storage-type="file" use-passive-ftp-mode="false" use-ftps="false">
        <root-dir>var/backup/tmp</root-dir>
        <file-name>dumpY5tVCg.tar</file-name>
    </dumps-storage-credentials>
</dump-specification>
[2013-10-29 14:53:47] exception during action processing
Stacktrace is: Traceback (most recent call last):
  File "/usr/local/psa/admin/share/pmmcli/pmmcli_daemon_actions.py", line 629, in process_daemontasks
    processed = processed and action_item.process(logger)
  File "/usr/local/psa/admin/share/pmmcli/pmmcli_daemon_actions.py", line 175, in process
    delta = datetime.datetime.now() - datetime.datetime.fromtimestamp( os.stat(file).st_atime )
OSError: [Errno 2] No such file or directory: '/var/backup/tmp/dumpY5tVCg.tar'
[2013-10-29 14:53:47] daemon finished job
I have:
-enough Disk Space
-writable var/backup/tmp (owned by root) (rwxrwxrwx)
I have not found this Error here - Anybody there who has an Idea ?
Install latest microupdate (latest is #20) at least. Then try to reproduce issue.
Oh more Problems
When I want to make the (M) Update via Plesk I get this message:
Code:
Parallels Panel pre-upgrade check...
PHP Warning: Directive 'register_globals' is deprecated in PHP 5.3 and greater in Unknown on line 0
PHP Warning: Directive 'register_long_arrays' is deprecated in PHP 5.3 and greater in Unknown on line 0
PHP Warning: Directive 'safe_mode' is deprecated in PHP 5.3 and greater in Unknown on line 0
PHP Warning: Directive 'magic_quotes_gpc' is deprecated in PHP 5.3 and greater in Unknown on line 0
WARNING: There are domains registered in Panel which URL does not have the http:// prefix. Such domains will not be shown on the Domains page. Check http://kb.parallels.com/en/113359 for more details.
Is this dangerous - or maybe ignored by the administrator in past at update to 11.5#3?
The Update-Pre-Check brings up this Warnings:
Code:
Is this a serious Problem? Or should this be occured already at update to 11.5.30#3 ? (so I could ignore)
I fear the lost of Domains from 11.5.30#3 to 11.5.30#20
