Resolved Apache not starting after Plesk updated!!
sanel_
Hello all, this morning I woke up to the nice surprise.. I got the email that the plesk updated but my websites all got bad gateway and this error message.
How do I fix this?
Unable to configure the web server: Execution failed. Command: httpdmng Arguments: Array ( [0] => --reconfigure-all ) Details: Execution failed. Command: httpdmng Arguments: Array ( [0] => --reconfigure-domains [1] => balkanmp3.ba,bolchat.com,bosnax.net ) Details: [2019-10-24 00:38:29.882] ERR [util_exec] proc_close() failed ['/usr/local/psa/admin/bin/apache_control_adapter' '--restart' '--restart-interval' '0' '--http-port' '7080' '--https-port' '7081' '--graceful'] with exit code [255] [2019-10-24 00:38:30.556] ERR [panel] Apache config (15718666970.82106800) generation failed: Template_Exception: Can not restart web server: Apache is down, start it instead of graceful Apache is down, start it instead of graceful INFO: [Thu Oct 24 00:38:25 MSK 2019]: Service: httpd, Action: start Trying to start service httpd... activating Oct 24 00:38:29 balkanmp3.ba systemd[1]: Failed to start The Apache HTTP Server. Oct 24 00:38:29 balkanmp3.ba systemd[1]: Unit httpd.service entered failed state. Oct 24 00:38:29 balkanmp3.ba systemd[1]: httpd.service failed. ***** problem report ***** Warning: start service httpd failed /usr/local/psa/admin/sbin/pleskrc execution failed: Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details. file: /usr/local/psa/admin/plib/Service/Driver/Web/Server/Apache.php line: 111 code: 0 Can not restart web server: Apache is down, start it instead of graceful Apache is down, start it instead of graceful INFO: [Thu Oct 24 00:38:25 MSK 2019]: Service: httpd, Action: start Trying to start service httpd... activating Oct 24 00:38:29 balkanmp3.ba systemd[1]: Failed to start The Apache HTTP Server. Oct 24 00:38:29 balkanmp3.ba systemd[1]: Unit httpd.service entered failed state. Oct 24 00:38:29 balkanmp3.ba systemd[1]: httpd.service failed. ***** problem report ***** Warning: start service httpd failed /usr/local/psa/admin/sbin/pleskrc execution failed: Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details.
file:
line: 111
code: 0
graceful
INFO: [Thu Oct 24 02:28:00 MSK 2019]: Service: httpd, Action:
start
Oct 24 02:28:04 balkanmp3.ba systemd[1]: Failed to start The
Apache HTTP Server.
Oct 24 02:28:04 balkanmp3.ba systemd[1]: Unit httpd.service
Oct 24 02:28:04 balkanmp3.ba systemd[1]: httpd.service failed.
Repair server-wide configuration parameters for web servers? [Y/n] a
Repair server-wide configuration parameters for web servers? [Y/n] y
Repairing server-wide configuration parameters for web servers .. [2019-10-24 02:28:21.493] ERR [util_exec] proc_close() failed ['/usr/local/psa/admin/bin/httpdmng' '--reconfigure-server'] with exit code [1]
[FAILED]
- httpdmng failed: [2019-10-24 02:28:20.959] ERR [util_exec]
proc_close() failed
[2019-10-24 02:28:21.360] ERR [panel] Apache config
(15718732880.80143700) generation failed: Template_Exception:
graceful
INFO: [Thu Oct 24 02:28:16 MSK 2019]: Service: httpd, Action:
start
Oct 24 02:28:20 balkanmp3.ba systemd[1]: Failed to start The
Apache HTTP Server.
Oct 24 02:28:20 balkanmp3.ba systemd[1]: Unit httpd.service
Oct 24 02:28:20 balkanmp3.ba systemd[1]: httpd.service failed.
file:
line: 111
code: 0
graceful
start
Apache HTTP Server.
â httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/httpd.service.d
âârespawn.conf
Active: activating (auto-restart) (Result: exit-code) since Thu 2019-10-24 03:42:31 MSK; 4s ago
Docs: man:httpd(8)
man:apachectl(8)
Process: 13012 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=1/FAILURE)
Process: 13010 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 13010 (code=exited, status=1/FAILURE)
Oct 24 03:42:31 balkanmp3.ba systemd[1]: Failed to start The Apache HTTP Server.
Oct 24 03:42:31 balkanmp3.ba systemd[1]: Unit httpd.service entered failed state.
Oct 24 03:42:31 balkanmp3.ba systemd[1]: httpd.service failed.
âârespawn.conf
Docs: man:httpd(8)
man:apachectl(8)
journalctl -xe
-- Subject: Unit httpd.service has finished shutting down
-- Defined-By: systemd
-- Support: systemd-devel Info Page
-- Unit httpd.service has finished shutting down.
Oct 24 03:45:29 balkanmp3.ba systemd[1]: Starting The Apache HTTP Server...
-- Subject: Unit httpd.service has begun start-up
-- Unit httpd.service has begun starting up.
Oct 24 03:45:29 balkanmp3.ba httpd[13322]: (98)Address already in use: AH00072: make_sock: could not bi
Oct 24 03:45:29 balkanmp3.ba systemd[1]: httpd.service: main process exited, code=exited, status=1/FAIL
Oct 24 03:45:29 balkanmp3.ba kill[13324]: kill: cannot find process ""
Oct 24 03:45:29 balkanmp3.ba systemd[1]: httpd.service: control process exited, code=exited status=1
Oct 24 03:45:29 balkanmp3.ba systemd[1]: Failed to start The Apache HTTP Server.
-- Subject: Unit httpd.service has failed
-- Unit httpd.service has failed.
-- The result is failed.
Oct 24 03:45:29 balkanmp3.ba systemd[1]: Unit httpd.service entered failed state.
Oct 24 03:45:29 balkanmp3.ba systemd[1]: httpd.service failed.
Oct 24 03:45:30 balkanmp3.ba postfix/smtpd[11079]: connect from unknown[45.142.195.5]
Oct 24 03:45:30 balkanmp3.ba sshd[13320]: Failed password for invalid user nataraj from 14.142.94.222 p
Oct 24 03:45:30 balkanmp3.ba plesk_saslauthd[7169]: No such user '[email protected]' in mail aut
Oct 24 03:45:30 balkanmp3.ba plesk_saslauthd[7169]: failed mail authentication attempt for user 'candid
Oct 24 03:45:30 balkanmp3.ba postfix/smtpd[11079]: warning: unknown[45.142.195.5]: SASL LOGIN authentic
Oct 24 03:45:30 balkanmp3.ba postfix/smtpd[11079]: disconnect from unknown[45.142.195.5] ehlo=1 auth=0/
Oct 24 03:45:31 balkanmp3.ba sshd[13320]: Received disconnect from 14.142.94.222 port 45670:11: Bye Bye
Oct 24 03:45:31 balkanmp3.ba sshd[13320]: Disconnected from 14.142.94.222 port 45670 [preauth]
file:
line: 111
code: 0
graceful
start
Apache HTTP Server.
[FAILED]
proc_close() failed
graceful
start
Apache HTTP Server.
file:
line: 111
code: 0
graceful
start
Apache HTTP Server.
âârespawn.conf
Docs: man:httpd(8)
man:apachectl(8)
âârespawn.conf
Docs: man:httpd(8)
man:apachectl(8)
journalctl -xe
Thank a lot i'm having the same problem too
Any solution for this thing yet?
service httpd status
Redirecting to /bin/systemctl status httpd.service
âârespawn.conf
Active: activating (auto-restart) (Result: exit-code) since Sat 2019-10-26 01:23:42 MSK; 756ms ago
Process: 2988 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=1/FAILURE)
Process: 2985 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 2985 (code=exited, status=1/FAILURE)
Oct 26 01:23:42 balkanmp3.ba systemd[1]: Failed to start The Apache HTTP Server.
Oct 26 01:23:42 balkanmp3.ba systemd[1]: Unit httpd.service entered failed state.
Oct 26 01:23:42 balkanmp3.ba systemd[1]: httpd.service failed.
And just to clarify, Obsidian was updated automatically from Onyx since I had automatic updates ON :oops:
Gives the same thing. I can login to the panel but no websites work and I tried everything I could find online but nothing helped.
And I did try repair and even reinstall completely but the same thing pops up. But now I'm also seeing this in the logs.
httpd[18811]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:7081
postfix/smtpd[23155]: warning: hostname ip-38-38.ZervDNS does not resolve to address 92.118.38.38
12985#0: *1574 connect() failed (111: Connection refused) while connecting to upstream
FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream
âârespawn.conf
Active: activating (auto-restart) (Result: exit-code) since Sat 2019-10-26 19:41:48 MSK; 1s ago
Process: 17471 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=1/FAILURE)
Process: 17399 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 17399 (code=exited, status=1/FAILURE)
journalctl -xe
Oct 26 19:48:36 balkanmp3.ba httpd[24133]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:7081
Oct 26 19:48:36 balkanmp3.ba systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
Oct 26 19:48:36 balkanmp3.ba kill[24205]: kill: cannot find process ""
Oct 26 19:48:36 balkanmp3.ba systemd[1]: httpd.service: control process exited, code=exited status=1
Oct 26 19:48:36 balkanmp3.ba systemd[1]: Failed to start The Apache HTTP Server.
Oct 26 19:48:36 balkanmp3.ba systemd[1]: Unit httpd.service entered failed state.
Oct 26 19:48:36 balkanmp3.ba systemd[1]: httpd.service failed.
Oct 26 19:48:40 balkanmp3.ba postfix/smtpd[19988]: connect from unknown[46.38.144.146]
Oct 26 19:48:41 balkanmp3.ba systemd[1]: httpd.service holdoff time over, scheduling restart.
Oct 26 19:48:41 balkanmp3.ba systemd[1]: Stopped The Apache HTTP Server.
Oct 26 19:48:41 balkanmp3.ba systemd[1]: Starting The Apache HTTP Server...
And this always come up the same when I tried to rebuild the conf. Plesk repair utility doesn't help at all.
New configuration files for the Apache web server were not created due to the errors in configuration templates: Can not restart web server: Apache is down, start it instead of graceful Apache is down, start it instead of graceful INFO: [Sat Oct 26 19:37:46 MSK 2019]: Service: httpd, Action: start Trying to start service httpd... activating Oct 26 19:37:50 balkanmp3.ba systemd[1]: Unit httpd.service entered failed state. Oct 26 19:37:50 balkanmp3.ba systemd[1]: httpd.service failed. ***** problem report ***** Warning: start service httpd failed /usr/local/psa/admin/sbin/pleskrc execution failed: Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details. . Detailed error descriptions were sent to you by email. Please resolve the issues and click See the details in Configuration Troubleshooter
I have no custom templates at all. I only run 1 website on the server so the same files apply to everything.
I have solved the problem after a couple of days searching the web for a solution but nothing helped.
Had to fix some things on HTTPD, SSL, NGINX, PHP, majority was the problem with PORTS already being used by another service.
All of this got messed up after the server updated itself.
âârespawn.conf
Active: active (running) since Sun 2019-10-27 03:41:05 MSK; 8s ago
Process: 15713 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=0/SUCCESS)
Process: 13543 ExecReload=/usr/sbin/httpd $OPTIONS -k graceful (code=exited, status=0/SUCCESS)
Main PID: 15734 (httpd)
Status: "Processing requests..."
Tasks: 146
Memory: 136.6M
CGroup: /system.slice/httpd.service
ââ15734 /usr/sbin/httpd -DFOREGROUND
ââ15807 /usr/sbin/httpd -DFOREGROUND
ââ15808 /usr/sbin/httpd -DFOREGROUND
ââ15810 Passenger watchdog
ââ15813 Passenger core
ââ15857 /usr/sbin/httpd -DFOREGROUND
ââ15876 /usr/sbin/httpd -DFOREGROUND
ââ15908 /usr/sbin/httpd -DFOREGROUND
Oct 27 03:41:04 balkanmp3.ba systemd[1]: Starting The Apache HTTP Server...
Same with me. The problem appears almost every week on sundays.
Unable to generate the web server configuration file on the host <server.server.com> because of the following errors:
Template_Exception: Can not restart web server: httpd stop failed
7 /usr/sbin/httpd processes are killed
INFO: [Sun Mar 1 12:18:06 EET 2020]: Service: httpd, Action: stop
Trying to stop service httpd... attempt to stop service httpd - service doesn't exist (missing unit file or not executable control script)
Warning: stop service httpd failed
Failed to list unit files: Connection timed out
Failed to get properties: Connection timed out
INFO: [Sun Mar 1 12:19:29 EET 2020]: Service: httpd, Action: start
Trying to start service httpd... attempt to start service httpd - service doesn't exist (missing unit file or not executable control script)
line: 111
code: 0
Please resolve the errors in web server configuration templates and generate the file again.
New configuration files for the Apache web server were not created due to the errors in configuration templates: Can not restart web server: INFO: [Sun Mar 1 12:24:14 EET 2020]: Service: httpd, Action: stop Trying to stop service httpd... attempt to stop service httpd - service doesn't exist (missing unit file or not executable control script) ***** problem report ***** Warning: stop service httpd failed /usr/local/psa/admin/sbin/pleskrc execution failed: Failed to list unit files: Connection timed out Failed to get properties: Connection timed out INFO: [Sun Mar 1 12:25:36 EET 2020]: Service: httpd, Action: start Trying to start service httpd... attempt to start service httpd - service doesn't exist (missing unit file or not executable control script) ***** problem report ***** Warning: start service httpd failed /usr/local/psa/admin/sbin/pleskrc execution failed: Failed to list unit files: Connection timed out Failed to get properties: Connection timed out . Detailed error descriptions were sent to you by email. Please resolve the issues and click here to generate broken configuration files once again or here to generate all configuration files. See the details in Configuration Troubleshooter
