Architecture problem
M
miskoo
Hello,
I have a server like this
host:~# uname -a
Linux 3v.cz 2.6.32-5-amd64 #1 SMP Mon Mar 26 07:00:19 UTC 2012 x86_64 GNU/Linux
host:~# file /bin/bash
/bin/bash: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.18, stripped
Debian 6.0.
This is for some specific reason (64b kernel, 32b userspace).
When installing anything for plesk, it installs 64-bit package by default. Apt-get installs correct 32-bit version.
How to fix this, please?
Thank you
Try to change /usr/local/psa/version
Maybe some fields in psa database should be updated too.
Current:
host:~# cat /usr/local/psa/version
11.0.9 Debian 6.0 110120608.16
Change to what?
Which fields in the database?
It happened when upgrading from 9 to 10 (now i have 11, problem persists)
You can try to override the architecture detected by autoinstaller. See its --help, look for 'override'. I'm not sure it'll help you, but it's worth a try. Please tell us if you succeed.
