Auto update problem
MarioFr
Hello,
my plesk control panel 11.5.30 has problems running the auto update of the panel.
During the upgrade, the server reboots even after an error message appears that shows the following message:
Can't parse /root/parallels/products.inf3: Error reading end tag.
What can I do to fix it?
If you have /root/.autoinstallerrc file - remove or rename it.
hi,
into the root folder of the server I get the following files:
.bash_logout
install.log.syslog
.rnd
.bash_profile
install.sh
.tcshrc
anaconda-ks.cfg
.bashrc
parallels
.autoinstaller
.cshrc
parallels_installer
.bash_history
install.log
plesk-installer
Which one should I delete or rename?
Thank you
