CMS Problem
R
Raied@
Hello,
When I migrated a domain which built using Content management system (CMS) PostNuke from Plesk 7.5 to Plesk 8.2, I get a black page when browsing it.
What is the problem?
Thanks
black or blank? :)
try to enable the display_errors value in /etc/php.ini file and restart Apache, probably you will get more info about the problem.
Also you can examine the log file for the domain, it can be also informative, the log file usually located in /var/www/vhosts/domain.com/statistics/logs/,
examine error_log in that directory.
