S
stevie@
Solved!
(http://forum.plesk.com/showthread.php?s=&postid=165911#post165911)
I've got a VPS with a fresh installation of Debian Sarge (without Plesk). The only thing to install which I selected during base-config was the mail-server, local delivery only. Did'n get any error messages, system is up to date.
Now I want to install Plesk 8.1. In the release notes I read, that I should install mod_ssl first. But as apache isn't installed at all, I skiped that.
I got and startet the AutoInstaller. Only selected Base Package. Everything's fine until deb-based installation starts. During the installation, there are several errors, all seem to be about stopping and starting services:
/tmp/qmail_8.1.0_debian3.1.build81061129.22_installing.log:
Later on:
Finally:
/tmp/psa-hotfix81061226.14.log:
If I now try to start psa with '/etc/init.d/psa start', I only get the message:
Does anyone have an idea how to fix this?
Kind regards
Stefan
Code:
WARNING!
During the stop found some problems(see log file: /tmp/qmail_8.1.0_debian3.1.build81061129.22_installing.log)
Code:
Trying to stop Qmail services... /var/lib/dpkg/tmp.ci/preinst: line 2316: /etc/init.d/qmail: No such file or directory
WARNING!
Continue...
STOP qmail-8.1.0-debian3.1.build81061129.22 installing (deb action: install) AT Mon Feb 5 11:23:31 CET 2007
START qmail-8.1.0-debian3.1.build81061129.22 installing (deb action: configure) AT Mon Feb 5 11:27:45 CET 2007
dpkg action:
Trying to set up default qmail permissions... done
===> Installing Qmail server
Trying to set... Trying to set... done
done
Configuring Qmail...
Trying to comment out comsat service record from /etc/inetd.conf... there is no comsat service record in /etc/inetd.conf
Trying to define super-server internet daemon type... inetd
Trying to restart inetd daemon... done
Trying to generate SSL certificates for TLS sessions... done
Trying to register service qmail... using /usr/sbin/update-rc.d
done
Trying to start Qmail services... Starting qmail: done
done
Trying to stop Qmail services... done
done
STOP qmail-8.1.0-debian3.1.build81061129.22 installing (deb action: configure) AT Mon Feb 5 11:27:56 CET 2007
Later on:
Code:
Trying to tune Admin apache...
Trying to start Plesk...
It is problem with inet daemon
Trying to start Apache server... done
Congratulations!
Plesk has been successfully installed on your server.
Finally:
Code:
Setting up psa-hotfix4 (8.1.0-debian3.1.build81061226.14) ...
Trying to stop Admin server...
WARNING!
During the stop found some problems(see log file: /tmp/psa-hotfix81061226.14.log)
Continue...
Trying to replace files and set up right permissions... done
Trying to start Admin server...
ERROR while trying to start Admin server
Check the error reason(see log file: /tmp/psa-hotfix81061226.14.log), fix and try again
Aborting...
dpkg: error processing psa-hotfix4 (--configure):
subprocess post-installation script returned error exit status 1
Setting up psa-imp (4.1.3-debian3.1.build81061129.22) ...
Setting up libpam-plesk (8.1.0-debian3.1.build81061129.22) ...
Trying to install PAM module... done
Errors were encountered while processing:
psa-hotfix4
E: Sub-process /usr/bin/dpkg returned an error code (1)
ERROR: Install command execution failed
Errors just before:
- Can't execute package installation command
ERROR: Installation failed
Code:
Trying to stop Admin server... It is problem with inet daemon
WARNING!
Continue...
Trying to replace files and set up right permissions... `/opt/psa/tmp/hotfix-81061226.14//opt/psa/admin/bin/httpsd' -> `/op$
`/opt/psa/tmp/hotfix-81061226.14//opt/psa/admin/bin/php' -> `/opt/psa/admin/bin/php'
`/opt/psa/tmp/hotfix-81061226.14//opt/psa/admin/htdocs/domains/subdomains/subdom_edit.php' -> `/opt/psa/admin/htdocs/domains$
`/opt/psa/tmp/hotfix-81061226.14//opt/psa/admin/sbin/mchk' -> `/opt/psa/admin/sbin/mchk'
`/opt/psa/tmp/hotfix-81061226.14//opt/psa/admin/auto_prepend/auth.php3' -> `/opt/psa/admin/auto_prepend/auth.php3'
done
Trying to start Admin server... It is problem with inet daemon
Aborting...
STOP hotfix-8.1.0-debian3.1.build81061226.14 installing (deb action: configure) AT Mon Feb 5 11:32:33 CET 2007
Code:
Kind regards
Stefan
