TITLE:
ACTUAL RESULT:
Different fileextension for PHP does not work with FPM-apache/nginx
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE:OS: CentOS Linux 7.4.1708 (Core), x86_64
3.10.0-693.el7.x86_64 #1 SMP Tue Aug 22 21:09:27 UTC 2017 x86_64
Produkt: Plesk Onyx 17.5.3 Update Nr. 27
PROBLEM DESCRIPTION:3.10.0-693.el7.x86_64 #1 SMP Tue Aug 22 21:09:27 UTC 2017 x86_64
Hello,
whte the Standard Handler changed like the Plesk-example
Onyx -> Domain -> Configuration Apache & nginx
own Value:
php-script .script
It does not work with the PHP-FPM-nginx or PHP-FPM-apache
The .script file whould parsed only with the old OS-Vendor-Parser mostly an old FastCGI-5.4.x version..
by the way: Standard .php scripts run with the correct PHP version
STEPS TO REPRODUCE:whte the Standard Handler changed like the Plesk-example
own Value:
php-script .script
- Onyx -> Domain -> Configuration Apache & nginx
own Value:
php-script .script - put an test.script on the Webserver
Content:
<?php echo phpinfo(); ?> - Select an FPM PHP-Interpreter FPM NGINX or apache / V7.x
The Webserserver script shows an old FASTCGI-php-version...
EXPECTED RESULT:phpinfo should show the phpversion 7.x.
