Question Docker Problem
DirkMA
Hi there,
I'm using Plesk Onyx Version 17.0.17 Update #20 on a Centos 7 Server. My Problem is, I try to use a Docker-Container, but i can't configure the Nginx Port Rules (photo attached).
Hi DirkMA,
well, sorry Dirk, but here are only two possible reasons, why you don't see ( for example: )
Plesk-Onyx_docker_nginx_port-mapping-settings.png​
First reason might be: The nginx - container isn't running.
Second reason, you didn't define the nginx port mapping manually and used "automatic port-mapping".
I saw this:
Requirements
  • nginx must be running in Plesk.
When saying nginx must be running in Plesk, it's the nginx in Tools & Settings > Updates & Upgrades > Add Components, or a running nginx docker container?
Thank you.
Hi Marston,
No, it is certainly a "real" NGINX - package, because otherwise you would map the ports from apache, if nginx isn't installed on your server. ;)
I have a 'real' NGINX package installed getting the same problem my container is running and if it try and hit my server ip and the port nothing...
in domain under docker proxy rule -> add rule I can't their is no options in the port option.
I also added to Additional nginx directives
location ~ ^/.* {
proxy_pass http://127.0.0.1:32827;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
but nothing...
Am i missing something?
