Health Monitoring not running
Status
Not open for further replies.
SAttraction
Basic Pleskian
All,
I have noticed that the Health Monitoring functionality within my main Plesk Panel 11.5.30 Update # 27 has stopped running.
I have already searched for such an issue and even though I have followed suggestions mentioned elsewhere (including this forum) - restarting the Health Monitoring service manually, ensuring that the service is running through command line (it is) - none of the solutions available apply nor work.
Please can someone provide some advice ?
If you need any more info., please let me know.
Many thanks in advance.
Darran
Hello,
Try to re-calculate Health Monitor on your server though following command
Code:
/usr/local/psa/bin/sw-engine-pleskrun /usr/local/psa/admin/plib/scripts/setup-health-monitor.php
Hello,
Code:
Hi there,
Many thanks for the quick reply. Appreciated.
I have run the above logged on through shell and it hasn't made any difference at all, I'm afraid. The Health Monitoring is still inactive - all services are still reporting 0 % ...
Any advice would be greatly appreciated. The service is running, according to queries through shell (top etc.), so I'm stuck as to what the issue is.
Darran
I have restarted Plesk and Health Monitoring is now working as it should. I can only presume that the actions in the above KBase worked.
Many thanks.
Darran
Status
