HELP HELP .!!!
Sia Magazi
I clicked something in change view section and an window came up and i cant get rid of it,i cant login to admin panel anymore.
ew-png.10837
This is the window that block's me from loging into Admin Panel. When I pres Cancel Then It logs out.....
And why you can't fill these fields and complete form?
Hello Sia )
Not to worry! What happened is that you switched to what we call "Power User View". It is an alternative Plesk interface more suited to managing small numbers of domains. To get back to managing your customers and resellers, fill in the fields (just type in any user name and generate a password automatically) and click OK - a subscription will be created for you, and you will be able to log in. Afterwards, you can switch back to the "Service Provider View" - just click Change View in the bottom left part of the screen and select the corresponding option. All your customers and their domains will be there )
