How to Fix Checking for system users home directories consistency...
onmglobal
Error: Web server reconfiguration failed: New configuration was not built.
[2015-11-05 02:42:52][INFO] ==> STEP 8: Checking for system users home directories consistency...
[2015-11-05 02:42:52][INFO] There is system user test in the psa database with home dir /var/www/vhosts/localhost.localdomain without corresponding record in the /etc/passwd file
[2015-11-05 02:42:52][WARNING] There are some inconsistencies in the Parallels Plesk Panel system users.
Please check http://kb.parallels.com/113490 for solution and log file /usr/local/psa/tmp/webserver_configuration_issues.log for details.
[2015-11-05 02:42:52][INFO] Result: Warning
