I need help websites offline
EladioL
Hello
I need urgent help, please.
I have VPS server with webfusion, but your support is very bad.
In this moment, email work, ftp work, but my sites of my server not visible.
Server work correctly, and I can access Plesk Panel without problem.
I review configuration dns and is good, but my sites not visible.
I suspect not work correctly Apache port.
I have ping and work correctly, but because not see my websites
Sorry, I'm spanish and my englis is basic.
Thank you very much
There are so many reasons that can cause your site from not working. And there's no 1 direct answer to such other than investigating the cause.
There questions such as:
Are you running Nginx?
By not working, do you get the default plesk page or they don't open at all?
If plesk default page shows up, then can your try rebuilding the vhosts with /usr/local/psa/admin/sbin/httpdmng --reconfigure-all
If not opening at all, make sure the DNS is working fine if plesk is your dns server.
PM me for details ...
Thanks for your help
I send pm with details.
Ngninx enable, but when disable show default page of webfusion.
Rebuilding host not working for me.
Thank you very much
Something very strange happened. I have enabled and disabled nginx.
Tripped a message on the console.
/opt/psa/admin/sbin/hmng: 1447: Syntax error: Bad fd number
And they have begun to be properly websites.
I do not understand. What's going on?. Malfunctions my vps?
Thank you very much for your help
