Pim Uijttewaal
Hi, when installing the Grafana extension I get the following error:
Could not install Grafana
Failed
After closing the error message I can in fact see the extension. But when I open it and click Open Application it opens mydomain/8443/modules/grafana/service/ and gives SERVER 403 forbidden.
Furthermore opening the Advanced Monitoring tab in Plesk shows: Could not check if Advanced Monitoring was installed correctly: Execution extension has failed with exit code 1, stdout: , stderr: /opt/psa/admin/sbin/modules//grafana/grafana-cli: line 2: /usr/sbin/grafana-cli: No such file or directory
The Fix Installation button cannot repair it.
I've also tried
plesk repair
plesk installer --select-release-current --reinstall-patch --upgrade-installed-components
No joy :-( Any suggestions? thanks, Pim
Failed
- The execution of post-install.php has failed with the following message:
- [2019-10-04 06:00:10.971] ERR [extension/grafana] Execution repository has failed with exit code 1, stdout: , stderr: ERROR:root:<urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)>
I've also tried
plesk repair
