Question "Keep websites secured" is not enabled by default in Plesk SSL, should I enable "Keep websites secured"?
shucm11
"Keep websites secured" is not enabled by default in Plesk SSL.
But my Let's Encrypt shows that the certificate is:
Valid To
May 7, 2022
Will be automatically renewed
As you can read here Securing Connections with the SSL It! Extension
Note: If you secure a domain with an SSL/TLS certificate from Let’s Encrypt and then add new domains, subdomains, domain aliases, or webmail to the subscription, you can have SSL It! automatically secure them by reissuing the SSL/TLS certificate from Let’s Encrypt. To do so, go to Websites & Domains > your domain > SSL/TLS Certificates and turn on the Keep websites secured option.
So, enabling this option will secure and renew all new domains, subdomains, domain aliases, or webmail will be added to your main domain. But the certificate of this main domain will be renewed independently of this option.
