Magento 2.04 problem with installing
CoyoteKG
Regular Pleskian
Hello, I tried to write in last thread, but it was closed.
Now, I try to install Magento 2.0 via App, not manualy, and I got this error
What can be a problem?
Error: The following error has occurred during the installation of application: Installation of magento at http://wogro.px90.info/ failed. Non-zero exit status returned by script. Output stream: 'PHP Fatal error: Uncaught exception 'InvalidArgumentException' with message 'Parameter validation failed' in /var/www/vhosts/px90.info/wogro.px90.info/setup/src/Magento/Setup/Console/Command/InstallCommand.php:150 Stack trace: #0 /var/www/vhosts/px90.info/wogro.px90.info/vendor/symfony/console/Symfony/Component/Console/Command/Command.php(236): Magento\Setup\Console\Command\InstallCommand->initialize(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #1 /var/www/vhosts/px90.info/wogro.px90.info/vendor/symfony/console/Symfony/Component/Console/Application.php(874): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #2 /var/www/vhosts/px90.info/wogro.px90.info/vendor/symfony/console/Symfony/Component/Console/Application.php(195): Symfony\Component\Console\Application->doRunCommand(Object(Magento\Setup\Console\Command\InstallCommand), Object(Symfony\Component\Console\Input in /var/www/vhosts/px90.info/wogro.px90.info/setup/src/Magento/Setup/Console/Command/InstallCommand.php on line 150 '. Error stream: 'PHP Fatal error: Uncaught exception 'InvalidArgumentException' with message 'Parameter validation failed' in /var/www/vhosts/px90.info/wogro.px90.info/setup/src/Magento/Setup/Console/Command/InstallCommand.php:150 Stack trace: #0 /var/www/vhosts/px90.info/wogro.px90.info/vendor/symfony/console/Symfony/Component/Console/Command/Command.php(236): Magento\Setup\Console\Command\InstallCommand->initialize(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #1 /var/www/vhosts/px90.info/wogro.px90.info/vendor/symfony/console/Symfony/Component/Console/Application.php(874): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput)) #2 /var/www/vhosts/px90.info/wogro.px90.info/vendor/symfony/console/Symfony/Component/Console/Application.php(195): Symfony\Component\Console\Application->doRunCommand(Object(Magento\Setup\Console\Command\InstallCommand), Object(Symfony\Component\Console\Input in /var/www/vhosts/px90.info/wogro.px90.info/setup/src/Magento/Setup/Console/Command/InstallCommand.php on line 150 '.
Check panel.log regarding related messages like:
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 127 bytes) in /var/www/vhosts/raesankar.com/httpdocs/vendor/magento/framework/App/ObjectManager/ConfigLoader.php on line 72
I installed it manually again, and I checked readiness.
I needed to set always_populate_raw_post_data=-1
maybe that was problem... And again, I did not expect that you will answer so fast, and I needed to finish this installation.
Later I will try to install Magento via Apps on some dev webspace
I tried to install it again in another webspace, and I got same message.
In attachment is panel.log, but I don't understand it
  • log.txt
