• Dear Pleskians! The Plesk Forum will be undergoing scheduled maintenance on Monday, 7th of July, at 9:00 AM UTC. The expected maintenance window is 2 hours.
    Thank you in advance for your patience and understanding on the matter.
Mailman Problem - Uncaught runner exception: unbound method
W
widomaker
If you try to send a post to a moderated mailing list, the message never shows up in the moderation queue. Here is what the error log says:
Mar 05 11:58:29 2008 (907) Uncaught runner exception: unbound method reason_noti
ce() must be called with NonMemberPost instance as first argument (got nothing i
nstead)
Mar 05 11:58:29 2008 (907) Traceback (most recent call last):
File "/usr/local/psa/mailman/Mailman/Queue/Runner.py", line 111, in _oneloop
self._onefile(msg, msgdata)
File "/usr/local/psa/mailman/Mailman/Queue/Runner.py", line 167, in _onefile
keepqueued = self._dispose(mlist, msg, msgdata)
File "/usr/local/psa/mailman/Mailman/Queue/IncomingRunner.py", line 130, in _d
ispose
more = self._dopipeline(mlist, msg, msgdata, pipeline)
File "/usr/local/psa/mailman/Mailman/Queue/IncomingRunner.py", line 153, in _d
opipeline
sys.modules[modname].process(mlist, msg, msgdata)
File "/usr/local/psa/mailman/Mailman/Handlers/Moderate.py", line 109, in proce
ss
Hold.hold_for_approval(mlist, msg, msgdata, Hold.NonMemberPost)
File "/usr/local/psa/mailman/Mailman/Handlers/Hold.py", line 212, in hold_for_
approval
reason = Utils.wrap(exc.reason_notice())
TypeError: unbound method reason_notice() must be called with NonMemberPost inst
ance as first argument (got nothing instead)
Any help would be great.....
Thanks W
P.S. FreeBSD 6.2 / Plesk 8.3 / Python 2.5.1 / Mailman 2.1.6 (from what we can tell)
I also ran the command 'check_perms' and here is the output:
directory permissions must be 02775: /usr/local/psa/mailman/archives/private/wabmembers/attachments
directory permissions must be 02775: /usr/local/psa/mailman/archives/private/wabmembers/attachments/20080208
directory permissions must be 02775: /usr/local/psa/mailman/archives/private/wabmembers/attachments/20080303
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/retry
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/shunt
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/out
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/bounces
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/in
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/commands
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/virgin
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/archive
directory permissions must be 02770: /usr/local/psa/mailman/qfiles/news
Warning: Private archive directory is other-executable (o+x).
This could allow other users on your system to read private archives.
If you're on a shared multiuser system, you should consult the
installation manual on how to fix this.
Problems found: 12
Re-run as mailman (or root) with -f flag to fix
Is this normal or does any of the following need to be fixed?
Thanks W
I will look into that. Thanks for the info. But on the other hand this is what PLESK installed. It also tells me that Mailman is up-to-date based on 2.1.6.... Anyone eles having this problem?
Are you still having issues with this?
I had the same issue and based on this thread and some various other threads on other sites managed to confirm that this is indeed an issue with python 2.5, after contacting plesk support there will not be a fix for this until Plesk9 at the earliest.
However this should fix it in (or it did for me)
cd /usr/ports/lang/python2.4 && make install clean # install python 2.4, may not be necessary
/usr/local/psa/mailman/bin/mailmanctl stop #stop current mailman
cp -pr /usr/local/psa/mailman /usr/local/psa/mailman.orig #precautionary backup
find /usr/local/psa/mailman -type f | xargs perl -pi -e 's/python2.5/python2.4/g' #replace python2.4 with python2.5 in all filles
/usr/local/psa/mailman/bin/mailmanctl start #start mailman back up.
From this point you should find this working.
Hope it helps.
