P
Pyromanci
I just updated from 9.2 to 9.3 and the zz010_psa_httpd.conf conf file got wiped. There is nothing in it beside the server name line. after that it's gone.
I received a email that said update failed. Here is that email.
Parallels Products Installer 3.5.0 (build at 2009-08-17 16:48 svn rev. 0) started at (timezone EST) Tue Mar 2 11:30:10 2010
Command line args: /usr/local/psa/admin/bin/autoinstaller --enable-xml-output --source-type=plesk --target=/root/psa --select-release-id=PLESK_9_3_0 --notify-email=XXX@xxxxxx --install-component=base --install-component=api --install-component=backup-ded --install-component=pmm-ded --install-component=psa-firewall --install-component=psa-vpn --install-component=watchdog --install-component=spamassassin --install-component=vault --install-component=horde
Try to find rcfile...
Autoinstaller rcfile not found.
Opsys detected as: os_vendor=CentOS os_name=Linux version=5.4 arch=x86_64 environment=~empty
Final opsys (with overriding) is: os_vendor=CentOS os_name=Linux version=5.4 arch=x86_64 environment=~empty
Starting installation of packages
Installing the package sw-cp-server-1.0-5.200902131202.centos5.x86_64
Stoppping SWsoft control panels server... stale pidfile. [ OK ]
Starting SWsoft control panels server...[ OK ]
Installing the package sw-engine-2.0-5.200910301646.centos5.x86_64
Installing the package plesk-base-9.3.0-cos5.build93091230.06.x86_64
Create user 'psaadm' and group 'psaadm'
Checking for the group 'psaadm'...
Group 'psaadm' already exists
Checking for the user 'psaadm'...
User 'psaadm' already exists
Create group swkey-data
Checking for the group 'swkey-data'...
Group 'swkey-data' already exists
Trying to add supplementary group 'swkey-data' for user 'psaadm'... already there
Create Mail accounts
Checking for the group 'popuser'...
Group 'popuser' already exists
Checking for the user 'popuser'...
User 'popuser' already exists
Changing shell for popuser.
Shell not changed.
Checking for the user 'mhandlers-user'...
User 'mhandlers-user' already exists
Changing shell for mhandlers-user.
Shell not changed.
Trying to got legacy variables... done
config updated
===> Updated /etc/psa/psa.conf
Trying to save legacy variables... done
Trying to generate default Plesk SSL Certificate... default certificate already exists
done
Installing the package psa-logrotate-3.7-cos5.build93091230.06.x86_64
Installing the package psa-php5-configurator-1.5.1-cos5.build93091230.06.noarch
===> configuring php5 using /etc/php.ini file
Trying to set memory limit to 32M... done
Trying to add '.' to 'include_path'... nothing to be done
done
Trying to set 'short_open_tag' to On... done
Trying to set 'file_uploads' to On... done
Trying to set 'safe_mode' to On... done
Installing the package psa-selinux-9.3.0-cos5.build93091230.06.noarch
Trying to install Plesk specific permissions... ***** upgrade problem report *****
set ftp_home_dir flag
getsebool: SELinux is disabled
done
Trying to reload service syslog... syslogd (pid 2950) is running...
klogd (pid 2953) is running...
Reloading syslogd...[ OK ]
Reloading klogd...[ OK ]
done
Plesk 9.3.0 rules already installed
Installing the package psa-proftpd-xinetd-1.3.1-cos5.build93091230.06.x86_64
3033
Reloading configuration: [ OK ]
Installing the package rsync-2.6.8-3.1.x86_64
Installing the package psa-manual-custom-skin-guide-9.0.1-0.279670.noarch
Installing the package psa-mail-driver-common-9.3.0-cos5.build93091230.06.x86_64
mv: cannot stat `/var/qmail/control/spf*': No such file or directory
Trying to executing mail_restore to synchronize mail server settings and Plesk Database... Number of arguments is invalid.
Unable to dump server-wide black/white lists into GreyListing database
done
Trying to start service mysqld... done
===> Checking for the necessary system accounts
Checking for the system groups and users necessary for MySQL...
Checking for the group 'mysql'...
Group 'mysql' already exists
Checking for the user 'mysql'...
User 'mysql' already exists
Checking for the system groups and users necessary for admin server...
Trying to add supplementary group 'psaadm' for user 'sw-cp-server'... already there
Checking for the group 'psaserv'...
Group 'psaserv' already exists
Trying to add supplementary group 'psaserv' for user 'apache'... already there
Trying to add supplementary group 'psaserv' for user 'psaftp'... already there
Trying to add supplementary group 'psaserv' for user 'psaadm'... already there
Checking for the group 'psacln'...
Group 'psacln' already exists
Checking for the system groups and users necessary for Apache...
Checking for the group 'apache'...
Group 'apache' already exists
Checking for the user 'apache'...
User 'apache' already exists
Trying to establish test connection... connected
done
===> Preparing upgrade
Trying to backup MySQL database... done
MySQL databases are dumped to /var/lib/psa/dumps/mysql.preupgrade.dump.gz
Stopping Plesk... done
Checking that /usr/local/psa/bin/chrootsh registered as login shell...
/usr/local/psa/bin/chrootsh already registered as a login shell
Trying to register service xinetd... using /sbin/chkconfig
done
Setting the default locale
The default locale is set to en-US (ENGLISH, UNITED STATES)
===> Installing rbash
Checking that /bin/rbash registered as login shell...
/bin/rbash is already registered as login shell
===> Installing psa database
Trying to define valid mysql credentials... Trying to establish test connection... connected
done
done
Trying to check psa database... Trying to find psa database... version is 0900
Trying to insert Hostname to the MySQL database... done
===> Installing Admin Server
===> Updating crontab...
install Backup Manager task is already performed by cron
Trying to untar Virtual Hosts directory structure... done
===> Installing Virtual Hosts Directory
===> Installing Apache Server
Trying to stop service httpd... httpd (pid 20396) is running...
Stopping httpd: [ OK ]
done
Copying apache files... done
===> Installing Quotas
Trying to change quota limits... done
/var has a xfs type. The quotacheck is not needed.
===> Installing and configuring Named Server
Checking for the system groups and users necessary for named (bind)...
Checking for the group 'named'...
Group 'named' already exists
Checking for the user 'named'...
User 'named' already exists
Stop running named daemon
Trying to stop service named... number of zones: 11
debug level: 0
xfers running: 0
xfers deferred: 0
soa queries in progress: 0
query logging is OFF
recursive clients: 0/1000
tcp clients: 0/100
server is up and running
named (pid 7234) is running...
Stopping named: .[ OK ]
done
Trying to untar named run-root directory structure... done
Trying to set up default permissions... done
Trying to start service named... rndc: connect failed: 127.0.0.1#953: connection refused
named is stopped
Starting named: [ OK ]
done
Trying to install chrooted environment... mknod: `/var/www/vhosts/chroot/dev/null': File exists
groups: application/x-shellscript
probably it will not work in chrooted acconts
WARNING!
During the register groups in chrooted environment found some problems(see log file: /tmp/psa_9.3.0_cos5.build93091230.06_upgrade.100302.11.34.log)
Continue...
done
===> Installing phpMyAdmin
done
===> Installing /usr/sbin/suexec replacement
Trying to backup original /usr/sbin/suexec... `/usr/sbin/suexec' -> `/usr/sbin/suexec.saved_by_psa'
done
===> Cumulative upgrade has been started
ERROR while trying to upgrade SQL database from 920
Check the error reason(see log file: /tmp/psa_9.3.0_cos5.build93091230.06_upgrade.100302.11.34.log), fix and try again
Aborting...
error: %post(psa-9.3.0-cos5.build93091230.06.x86_64) scriptlet failed, exit status 1
Trying to install PAM module... done
done
Trying to upgrade persistent database storage... done
done
Trying to create temporary database storage... done
done
ERROR: An error occurred during installation of packages.
Attention! Your software might be inoperable.
Please, contact product technical support.
Parallels Products Installer.
Shell not changed.
Shell not changed.
config updated
done
done
done
done
3033
done
done
done
done
done
done
debug level: 0
xfers running: 0
xfers deferred: 0
tcp clients: 0/100
done
named is stopped
done
WARNING!
Continue...
done
done
done
Aborting...
done
done
done
