max_input_vars and php.ini path
pleskuser
Hello, I need to increase the max_input_vars for prestashop, I add this variable in the php "Additional configuration directives" and restar the server but nothing change.
Also I try to change it directly into php.ini with same results, nothing change.
In the phpinfo() says
Configuration File (php.ini) Path /usr/lib
Loaded Configuration File /usr/local/lib/php.ini
I enter by telnet and the php.ini isn't in that directory...
how can I change it?
thanks.
Try editing the one in /etc/php.ini
NB: Are you running php as an apache module or CGI application?
Hello,
I change it in the /etc/php.ini and nothing
I try php in CGI, fastCGI and Apache, but nothing change, in the phpinfo always see CGI/FastCGI
I change this in the service plan->basic->hosting parameters
Thanks
did you remember to restart apache and php after the changes?
max_input_vars for Prestashop
Hello together,
have found a solutions for Prestashop user
just insert in Plesk Panel >>>Customizing Subscription>>>> YOURDOMAIN.com
in the Tab PHP Settings scroll down until you can see the textarea like at my screenshot and insert there the Value you need for example max_input_vars = 5000 then click on save and thats it now you can work on the translation.
Greetz
Nico
Hello together,
Greetz
Nico
Just signed up to write you a big "THANK YOU" Nico.
THANKS
Worked perfect
I have had the same issue. I'm just adding this for the people who will need this in the future. Editing stated php.ini file in phpinfo(); doesn't work. You should do it from Plesk Panel as it has been said above.
