Issue No connection FTP - Service is up and running and listen
Robin Schumacher
Hello unfortunately I can not establish a connection with FTP since yesterday, unfortunately I built with the rights of the Ornder on the server.
Connect with 145.XXXXXXXXX.
Status: Connection established, wait for welcome message ...
Error: Connecting to the server failed
root @ plesk: ~ # /etc/init.d/xinetd restart
[ok] Restarting xinetd (via systemctl): xinetd.service.
root @ plesk: ~ # /etc/init.d/xinetd status
● xinetd.service - LSB: Starts or stops the xinetd daemon.
Loaded: loaded (/etc/init.d/xinetd; bad; vendor preset: enabled)
Active: active (running) since Tue 2018-02-20 17:06:39 CET; 2s ago
Docs: man: systemd-sysv-generator (8)
Process: 32547 ExecStop = /etc/init.d/xinetdstop (code = exited, status = 0 / SUCCESS)
Process: 32556 ExecStart = /etc/init.d/xinetdstart (code = exited, status = 0 / SUCCESS)
CGroup: /system.slice/xinetd.service
└─32568 / usr / sbin / xinetd -pidfile /run/xinetd.pid -stayalive -inetd_compat -inetd_ipv6
Feb 20 17:06:39 plesk xinetd [32568]: removing daytime
Feb 20 17:06:39 plesk xinetd [32568]: removing discard
Feb 20 17:06:39 plesk xinetd [32568]: removing echo
Feb 20 17:06:39 plesk xinetd [32568]: removing time
Feb 20 17:06:39 plesk xinetd [32568]: xinetd Version 2.3.15 started with libwrap loadavg options compiled in.
Feb 20 17:06:39 plesk xinetd [32568]: Started working: 2 available services
root @ plesk: ~ # lsof -i tcp: 21
COMMAND PID USER FD TYPE DEVICE SIZE / OFF NODE NAME
xinetd 1963 root 5u IPv6 132404114 0t0 TCP *: ftp (LISTEN)
Thanks and greetings Robin
The issue may be caused by SELinux. Check that you have:
# getenforce
Enforcing
If it is so, change that to permissive
# getenforce
Permissive
