- Server operating system version
- Ubuntu 22.04.5 LTS
- Plesk version and microupdate number
- Plesk Obsidian 18.0.65
The error occurred when I wanted to migrate something via Plesk migrator, an error occurred,
then I uninstalled the Plesk migrator.A new installation is no longer possible but for all uninstalled components
It is possible that the performance booster has changed something in the database.I reset it but it didn't work either.
[2024-11-09 21:24:15.101083] Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_18_0_65', sequence='post', stage='rollback', sequence_order='1', operation='install', exec_cmd='rm -f /tmp/pp-bootstrapper-mode.flag; rm -f /var/lock/parallels-panel-maintenance-mode.flag; touch /var/lock/parallels-panel-upgrade-failure.flag; :'', m_arch='', exit code: 0, output: ~empty
[2024-11-09 21:24:15.102167] Überprüfung der Komponenten und Produkte wird gestartet...
[2024-11-09 21:24:15.102190] FileFetcher: get file (~empty)/report-update
[2024-11-09 21:24:15.102242] Datei wird heruntergeladen report-update: 0%
[2024-11-09 21:24:15.165897] Datei wird heruntergeladen report-update: 100% fertig.
[2024-11-09 21:24:15.166113] FileFetcher: get file (~empty)/pool/PSA_18.0.65_15773/examiners/py_launcher.sh
[2024-11-09 21:24:15.166146] Datei wird heruntergeladen pool/PSA_18.0.65_15773/examiners/py_launcher.sh: 0%
[2024-11-09 21:24:15.186116] Datei wird heruntergeladen pool/PSA_18.0.65_15773/examiners/py_launcher.sh: 100% fertig.
[2024-11-09 21:24:15.549490] Examination executed ["/root/parallels/pool/PSA_18.0.65_15773/examiners/py_launcher.sh" "/root/parallels/report-update" --op update --rc 1 --start-flag /var/lock/plesk-report-update.flag --to=18.0.65.0 --from=18.0.65] with code 0
Output:
~empty
Error:
mysql: unknown variable 'innodb_flush_log_at_trx_commit=2'
mysql: unknown variable 'innodb_flush_neighbors=0'
mysql: unknown variable 'innodb_flush_method=O_DIRECT_NO_FSYNC'
mysql: unknown variable 'innodb_io_capacity=450'
mysql: unknown variable 'innodb_random_read_ahead=ON'
mysql: unknown variable 'table_open_cache=5000'
mysql: unknown option '--mysql -max-connections 151'
mysql: unknown variable 'innodb_buffer_pool_size=728462131'
mysql: unknown variable 'innodb_log_file_size=182115532'
[2024-11-09 21:24:15.549733] Execute command /opt/psa/admin/bin/send-error-report install --version 18.0.65
[2024-11-09 21:24:15.550573] Warning: Failed to detach from parents cgroup, installer might be unexpectedly killed later by the system
[2024-11-09 21:24:15.552156] Error: Während der POST-Installation ist ein Fehler aufgetreten (siehe Protokoll für Einzelheiten).
Warnung! Es wurden nicht alle Pakete installiert.
Bitte prüfen Sie, ob Ihre Systemdienste betriebsbereit sind.
Bitte beheben Sie dieses Problem und versuchen Sie, die Pakete erneut zu installieren. Rufen Sie https://support.plesk.com/ auf, um eine Lösung für dieses Problem zu finden.
