open Panel with IP and relay (Secure Connection Failed)...
saatchi
Basic Pleskian
Hello,
I installed a new Plesk 11 on a fresh Linux server. I open the panel with the server IP in several times and config it (Specially Small Business). But after one log out, when I tried to open it, browser redirect to this address:
https://domain.com:8443/relay
and in this page I have SSL error:
An error occurred during a connection to domain.com:8443.
SSL received a record that exceeded the maximum permissible length.
(Error code: ssl_error_rx_record_too_long)
my domain.com is the hostname (host name can't be IP address) and this domain is not assign to this server, yet. I wanted modify the new server and after config, migrate my sites to this new one and change the NSs. I know that this error is for the DNS error when it try to open with domain.
SO please help me to return to the last config to open panel with IP.
I disabled SSO and now I can access to the panel.
# /usr/local/psa/bin/sso --disable
So I will manage and migrate my sites and after that will enable it. In this case, I just can't access to Small Business.
Wow. For some plans management, I've to switch to small business and because of this post issue, I can't go there.
when I click it, I have the same error and switch to that domain:
https://domain.com:8443/plesk-billi...tps://my_server_ip:8443&context=billing-plans
so in the address bar, I changed domain.com to my_server_ip manually and Enter, but it redirect page to https://domain.com:8443/relay , again!
Now I know that I've to change my small business setting and change domain.com to server IP, but where and how!? Could you please help me to find the file to change it (via command line).
My OS is CentOS 6.2
Try to run
/usr/share/plesk-billing/integration --command=repaiall --hostname=domain.com
where domain.com is your valid hostname which is correctly configured both locally (on the server) and globally (say, from your home computer). Just run "ping domain.com" on the server in command line and on home computer in command line and check that it is resolved into correct IP.
thank you for your answer. Finally, I changed the DNS of the main domain and I open small business with that.
