P
pppplus
How is it possible to open port 43 as to do whois requests.
I try to modify firewall in plesk, but have always errors.
I have 2 firewall in my plesk manager :
- one under module
- one under virtuozzo
I can modify the virtuozzo firewall (but no effect, always fsockopen error on port 43)
I try to modify module firewall and I have this message :
- one under module
Erreur: Impossible d'activer la configuration du Firewall:
safeact: safeact: /usr/local/psa/var/modules/firewall/firewall-new.sh failed:
iptables: Unknown error 4294967295
proc_close() failed: mktime() [<a href='function.mktime'>function.mktime</a>]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CET/1.0/no DST' instead
