Parallels Premium Antivirus License Problem after MU24
AdelM
Basic Pleskian
Hello
I purchased a Plesk Panel Powerpack via my Hosting Provider.
After updating Plesk Panel to 10.4.4 #24 I discovered that Parallels Premium Antivirus is no more active.
When I went to Home > Tools & Settings > License Management > Additional License Keys but can't find any license of Parallels Antivirus.
I tried to "Retrieve Keys" in order to reinstall them but no success.
Any Help will be appreciated.
Cheers
Adel
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
Version : Parallels Plesk Panel v10.4.4_build1013111102.18 os_Debian 5.0
Panel version 10.4.4 Update #24
OS : Linux 2.6.18-028stab070.7
Key number : PLSK.01321261.0013
PROBLEM DESCRIPTION
After upgrading to MU24 I started receiving email see below for example :
/etc/cron.daily/drweb-update:
ERROR: Dr.Web (R) Updater: Blocked license key !
ERROR: Dr.Web (R) Updater: cannot download timestamp !
ERROR: Dr.Web (R) Updater: failed to download new/updated files from http://update.fr1.drweb.com/unix/500 !
/etc/cron.daily/logrotate:
[Sun Apr 01 04:54:02 2012] [warn] The Alias directive in /etc/apache2/apache2.conf at line 244 will probably never match because it overlaps an earlier Alias.
STEPS TO REPRODUCE
ACTUAL RESULT
Can't find any license of Parallels AntivirusIn Home > Tools & Settings > License Management > Additional License Keys , And Parallels antivirus is no more updated.
EXPECTED RESULT
ANY ADDITIONAL INFORMATION
Tried to "Retrieve Keys" in order to reinstall them but no success.
The problem is obviously occurs on Dr.Web update servers' side. Did you try to contact Dr.Web support?
Thanks Igor for your reply.
Problem resolved, nothing to do with plesk or MU24.
The problem came from my provider who didn't add the license.
Best regards
Adel
