PHPMyAdmin Export not possible - Fix does not work
ehrenwert
Basic Pleskian
Hello dear Parallels-Team,
well, I've got a tiny little problem: If a customer tries to export a mysql-database he gets the following error: export.php not found.
Some tutorials show, that the memory-limit in the /usr/local/psa/admin/conf/php.ini has to be increased.
I did this (512M). After restarting the psa it works only once. Having a second try it does not work again (export.php not found) - in these cases I have to increase the memory-limit again.
What can I do here?
Hi and thank you for your answer.
No, I did not try it yet. As I'm on a mobile device with low battery at the moment I did not have enough time to search for a manual, which shows, how to exclude sth. from ACP. Could you help me out?
Check that you have following parameters:
# cat /usr/local/psa/admin/conf/php.ini|grep apc.enabled
apc.enabled = 0
# cat /usr/local/psa/admin/conf/php.ini|grep memory_limit
memory_limit = 256M
